Hello all,
I am looking to replace the honda bf50 controller on my Mac26x. I'm very interested in buying a Dometic SeaStar Side Mount Control.
Does anyone have any experience with these: http://www.seastarsolutions.com/wp-cont ... ount-3.pdf
I'm wondering if I have the install the guide wires entering from the side. I want to install it on the 26x pedastal with the control wires pointed down. I'm also concerned that i would have the forward and reverse controls inverted? Any thoughts or suggestion from (or alternatives that will work with the honda engine and the SeaStar cables).
Thanks!!
Honda BF50 Controller on Last Leg
DaveC426913
Re: Honda BF50 Controller on Last Leg
I wonder if it's possible to rotate the handle's orientation when installing. If so, you could mount the controller base with cables downward and still attach the handle pointing up as usual.
Perhaps as the manu, and/or see if it can be custom rigged that way.
'course that would prolly void the warranty.
[ EDIT ] Oh shoot. The interrupt/deadman switch may get in the way.
MacX 2000 Honda BF50A 'SeaSaw'
