A New Journey Begins for OverEasy - 2023/2026
This is a place to document your trips with your boat. Tell us about your journeys. Share your experiences. Post your pictures.
OverEasy
Re: A New Journey Begins for OverEasy - 2023
Post by OverEasy »
Hi All!
Didn’t get out on Over Easy today…😕… chores to do…
Did get to play mechanic on Scrambled’s engine though (recall it crapped out a couple weeks back).
Figured simplest things first..
- tried to crank it in the drive way
>> nope, turns over fine but no vrrmmm
- tried checking spark
>> ⚡️ 🤬⚡️🤬⚡️… yup 👍 got spark ⚡️
- tried pulling the plugs
>> yup plugs both looked fine for run plugs
>> no fouling and proper gap
- put plugs back in after cranking it over with them out
>> nope 👎 no vrrmmm
- when and got new plugs ($10 each!!🙄🫣) & put them in
>> VVVRRRRRMMMMMMMMM!!! 👍👍
——Hmmmm 🤔 wonder why???
——Old plugs sparked but no vrrmmm
——New plugs sparked and then VVRRRRMMMMMM
- ok, so now out comes the water muff and the garden hose so we can run it at idle for while to see if it fouls or something
>> Runs fine, acceleration, decelerating, long idles….Runs fine… it’s a mystery.
So I invested in some cheap tools (13/16 deep socket/3/8 ratchet wrench/multipoint screw driver, 4 extra Plugs ($40), small bottle of 2-stroke oil, head lamp, BIG CHANNEL LOCK PLIERS and a water tight plastic ammo box from Harbor Freight).
Now if it happens again I’ll be better prepared to at least try and effect self rescue (before pestering TowBoat again.
The ammo box is big enough to also add a couple water bottles, flares, lanyard knife, first aid stuff and a sealed up dry energy bar or two along with anything else one should put in a mini boat E-box suitable for a runabout/tender. Given the shallows around here I’ll probably search out an old suitable used spare prop as well.
So the day wasn’t entirely spent on chores 😎.
Was a long day all the same.
Got to enjoy a beautiful moon rise very the Beaufort River coming home from the store!😃👍
Best Regards
Over Easy 😎😎🐩🐈
OverEasy
Post by OverEasy »
Hi All!
While it had been on our “delayed for maybe next year ‘To-Do’ List serendipity came along to help us out!👍😎😎👍
A neighbor who is moving to Europe posted on our community marketplace that they had a nearly new (total of 6hr run time) Honda EB2000i generator for sale at a VERY reasonable price. A quick phone call later we had a deal and we are now the owners of a VERY well kept VERY low time portable generator.
The “EB” part of the generator title denotes it as targeting the construction/contractor market crowd as its purportedly a little more robust and has a built-in GFIC capability.
Here are some of the general specs for those interested:
This aspects are actually desirable features to us for its intended utilization with Over Easy!
While we haven’t hoisted it aboard for a trial fit on Over Easy as yet by it appears to pass the eyeball check satisfactorily!👍😎😎👍
At nearly 55 lbs when fully fueled and oiled this isn’t a lightweight and will take a bit of thinking when it does come time to hoist it aboard. Initial thoughts are to make some sort of ‘mounting deck’ under the helm seat that would allow for the generator to transit crosswise but then allow it to turn 90 degrees (so the exhaust points aft) when running.
While this model generator doesn’t have a 12VDC output we figure it’s probably not an issue as we already have our automatic wall plug battery charger aboard to top up the batteries.
So far - So good!
Best Regards
Over Easy 😎😎🐩🐈
OverEasy
Post by OverEasy »
Hi All!
Another beautiful day on our SC coastal estuaries!
Beautiful sunset on our way back to share with you.
The Admiral was really enjoying the moment…
Best Regards
Over Easy
Post by Jimmyt »
Very nice! Thanks for posting!
OverEasy
Post by OverEasy »
Hi All!
We hope everyone is well and happy. Spring has sprung (officially) and the weather is warming. Hopefully those still snow and ice bound up north have seen at least a decrease in the depth of all that frozen stuff.
Here in South Carolina it has been wonderful. No snow, no ice, no freezing temperatures for at least the past several months.
This is in comparison to what we have previously experienced in New Hampshire during most of the previous decades (where there is still snow on the ground and the pond is still ice covered!). There might be something to this low budget snowbirding thing!
Got to admit that I haven’t been as active with the home renovations down here as I had anticipated. Just not as dexterous as I once was.
Seems things really do take longer as one gets older. Phhpppttttt!!!!
Though it finally appears that the yard clearing of the impassable thickets if vines has been completed ✔️ 👍
We pulled out more than 8 densely packed minivan sized compressed bundles of vines!😳😳🫣😵‍💫
It’s incredible how much nicer everything looks now 😊😊!
Next would be selecting and planting flowering shrubs to ideally have nearly year round flowers 🌸 🌺 💐 .
We might take a break from that though for a while and let things stabilize while doing what we can to keep those vines from coming back.
Constant mowing of any and all resurgent shoots seems to be the method of choice down here to deal with that problem…. That takes time.
As a reward for our labors we have gotten out on Over Easy several times on the weekends.
We have traveled up from our slip in Port Royal north past Beaufort up as far as Sam’s Point landing a couple times.
We have traveled south as far as Hilton Head Island which we just accomplished yesterday!
It was beautiful weather with clear skies and warm temperatures in the mid 70s for most of the day.
We had a very nice lunch when we arrived in Hilton Head landing at the nice day dock there.
The outbound and inbound legs each took little over 3 hours each way fo a total run time of roughly 7 hours.
Lots of things to see such as Osprey, herons, turtles, egrets and dolphins along with a beautiful sunset over Paris Island USMC Training facility
We arrived back at our slip in the waning light just after sunset with a strong incoming high tide pushing us diagonally into our slip.
We did a missed approach the first attempt but backed away for a second go with better results.👍👍🎉
The new Suzuki engine ran like a champ.
Now that it has broken in it has a WOT of 5400 rpm which is right where the factory recommends.
With full ballast the GPS over ground speed was averaging about 15 mph but that was also contending with tidal and river currents.
The fuel consumption for our trip was less than 12 gallons of the 24 gallons available which is remarkable compared to our old 50 hp Tohatsu 2-stroke engine. Most of the open water portions of the trip was run at 4000 to 5400 rpm with GPS over ground speeds between 10 to 16 mph. For future reference this should generally provide us with at least 12 hours (or substantially more at lower RPMs and water speeds closer to our hull speed of 6 knots) of run time which will come into play our desire for extended cruising of the ICW. We are very happy with the investment in our new Suzuki DF60AV.
Again, we hope all goes well for everyone!
Best Regards,
Over Easy 😎😎🐩🐈
OverEasy wrote: Mon Apr 03, 2023 2:34 am We hope everyone is well and happy. Spring has sprung (officially) and the weather is warming. Hopefully those still snow and ice bound up north have seen at least a decrease in the depth of all that frozen stuff.
Last Saturday brought 2 feet of the wonderful white glorious frozen dihydrogen monoxide. :(
So thanks for the trip review and photos to live vicariously.
Your experience seems inline with our Suzi DF70. What size prop are you spinning?
We rarely run WOT which is probably bad but very comfortable.
I do run exclusively Premium Ethanol Free fuel.
OverEasy
Post by OverEasy »
Hi Russ!
We can relate to your disappointment in the additional frozen stuff as we’ve officially failed as ‘snowbirds’ 3 out of the past 6 years and have weathered many unending winters in NH the years before 🙄🫣
Our first winter in NH back in 2002 had an accumulation of over 8 feet!
Then a couple of years later there was the pre Christmas ice storm that knocked out power in the region for more than 2 weeks!
We can still hear the drone of neighborhood generators 🙄😵‍💫 whenever the cold weather arrives suddenly :D :D
We’re running a 9 pitch prop currently. It’s the smallest standard prop Suzuki offers.
When we were initially prop sizing for our particular setup the 9 pitch wasn’t allowing our new engine to reach the full WOT recommended RPMs. We had a prop modified to a 7 pitch but it tripped the automatic over rev protection well before we ran out of throttle throw. An 8 pitch might have hit the sweet spot but we decided that the 9 pitch was good enough 👍 for our needs.
Currently we have about 87 hours on the Hobbs hour meter and as the engine has worn in the the RPMs have gradually climbed up to the current 5400 rpm which is now just inside the 5300-to-6300 range recommended by Suzuki. This works nicely for our anticipated usage desires of cruising the ICW and other locations like Lake Champlain for extended periods of time.
With a full equipment, fuel and personnel load and empty ballast at WOT we get consistently into the mid low 20s mph for over ground speed via GPS.
with the same full equipment, fuel and personnel and full ballast at WOT we seem to get consistently into the 15-to-16 mph for over ground speed via GPS.
At 2000-to-2500 rpm range with the same full equipment, fuel and personnel and full ballast we seem to get a fairly consistent speed range of 6-to-8 mph speed over ground via GPS. (The variability is due to wind/current variation). This is inline with our targeted cruising hull speed of 6 knots = 7 mph. Talking with the Suzuki Engineering Representative this shouldn’t be a problem as we won’t be lugging the engine in the speed /rpm range when operating for extended periods of time while cruising along.😎😎👍👍.
(We have kept the custom 7 pitch prop as a backup spare (should it ever be needed) but I really should get a spare prop nut before we really venture farther afield into the boonies of the ICW.)
We hope that your Spring Thaw arrives soon so you can get back out on the water and enjoying your Mac!
Best Regards
Over Easy 😎😎🐩🐈
OverEasy
Post by OverEasy »
Hi All!
It’s mid April and the weather has been beautiful!
So glad we have been able to be here in Beaufort SC this time of year!
Sooooo much better than what we went through in NH last year this time!
Troubleshooting:
We’ve been able to get out on the water at least once if not twice a weekend since launching Over Easy down here.
Our rental slip is very much appreciated!
Finally deinstalled our errant ‘within the hull’ transducer with the side scan capabilities.
(As some may recall it went AWOL a while back and as a stopgap I robbed the little 4” chartplotter and transducer from our runabout Scrambled and installed it to Over Easy.)
After getting it out I rigged it up on some strings and placed it over the side while in the marina slip.
Lo and behold it’s still working… Now why did it go AWOL?🤔
Possibly a pinched wire? I dunno……
I’m thinking that…. As involved as it was to install it and deinstall it that I just might get a simpler new transducer for the ‘within the hull’ function and make a slide bracket to deploy the fancy side scan from the stern when desired. That way we’ll have a primary transducer for depth and general bottom mounted ‘within the hull’ and a back up in the water off the stern when desired as a “spare “.
We want to have the bigger/better chartplotter for trips to map out our routes in advance when possible.
It’s also a whole lot easier to read too!
For the immediate future (until we haul out) I believe that I’ll leave the small system installed (as a backup) and just add the larger chartplotter/side scan sonar with the in water slide mount back on.
Maintenance:
We did our 1st 100 hour oil & filter change this past weekend while in our rental slip with the help of a vacuum extractor.
We got the extractor from Harbor Freight for about $100.
It worked like a champ!
Simply removed the engine cover, checked the oil level (which was just at the top mark on the dip stick), ran the engine at idle for 2to3 minutes just to stir things up, then shutdown, opened the oil fill port, insert the siphon line into the dipstick port and apply vacuum with the integral hand pump.
The used oil is evacuated and stored into the integral holding tank in about 5 to 10 minutes.
It did a great job of getting all 3 quarts of oil out.
Then placed a couple paper towels under the side mounted oil filter, removed the filter with a ratchet and socket, lubed the seal on the new filter and installed it.
Refilled the engine with 2-1/2 quarts, restarted the engine for 2to3 minutes at idle to fill the filter, stopped the engine, checked oil level, added the remaining 1/2 quart, restarted the engine at idle for 2to3 minutes, stopped the engine, checked oil level which was now at top mark on the dip stick ( which indicates that the extractor did indeed remove all the relevant old engine oil).
No drips, no spills at all!
No need to haul out, through, easy to use, easy to transport with integral handle, easy to cleanup by pouring old oil from integral canister into gallon jug to drop off at local transfer (or gas) station for proper disposal.
Great investment!
Note: For those concerned about any ‘sludge’ remember we are changing our oil every 100 hours along with the filter, we extracted 3 full quarts of capacity of old oil and replaced with 3 full quarts of new oil, we also stirred the old oil (by running the engine) before removal and ensured that the new filter was filled (by running the engine) before topping off the oil level. Regular oil and filter changes are the best way to help a long and productive engine life.
I also replaced the original start battery that came with Over Easy by our very nice POs that had a date code of 04/2019.
It was getting weaker and not holding a charge as well as it had been.
We replaced it with a slightly larger capacity dual purpose marine start/store battery from West Marine to match the secondary battery we previously installed in the spring of 2021.
Aside: I may try to “rejuvenate” or “recondition” this old battery as an experiment. It wouldn’t hurt and might be interesting to see if it actually works out like some have claimed. If it does then it could be a good secondary battery for our runabout Scrambled.
Performance:
We’ve taken several day trips specifically in mind to check out our new Suzuki DF60AV engine performance.
At near WOT we get about 6 hours of run time per 12 gallons of fuel at about 15 mph ground speed via GPS with full ballast, two adults, one dog and pretty much our standard anticipated cruising equipment. This yields a rough 180 mile range with 24 gallons aboard (two 12 gallon tanks) or roughly 7.5 mpg.
At 2000 rpm we get about 12 hours of run time per 12 gallons of fuel at about 7 mph ground speed via GPS under the same old conditions. This yields a rough 168 mile range with 24 gallons aboard or roughly 7 mpg.
Funny that the range at near WOT & @2000 rpm are so similar…🤔… but these numbers don’t necessarily account for River and tidal flow currents as we are using the GOS over ground speed and not the actual through the water hydrodynamic speed.
For extended trip planning purposes we’re gonna plan on 100 mile legs between refueling stops (or less) as that should give us an additional 1/3 range capacity to help with any SNAFUS from becoming FUBARS.
Trip Planning:
That leads us to the aspect of the Admiral and I discussing the potential of a week long trip from Beaufort SC up to Charleston SC and back next month. 😎😎
The waterway ground distance from our slip in Port Royal/Beaufort SC to Fort Sumpter Charleston SC is about 100 miles each way.
That roughly allows for 2 to 3 days out, 2 to 3 days back and 2 to 3 days for cruising around Charleston/Battery Park/Fort Sumpter and other ground based sightseeing.
Near Term Future:
- Get a current player chart of the ICW between Savanna GA and Charleston SC.
- Get a ICW travelers guide of the ICW between Savanna GA and Charleston SC.
- Get stern slide bracket installed for side scan sonar transducer & reinstall bigger/better chartplotter
- Finish & install of the “Blow Ballast!” System I’ve been putting together
SC Home Projects:
Installed a 120 foot long 16 foot high spring/cable & pulley dog run in the backyard for my daughter’s dogs. One has a great big playful gentle 60+ lb Cattle Dog and the other has a beautiful energetic Standard Poodle. This will give them each room to be outside to romp and play when they are visiting to their hearts content.
Now that we’ve removed about 6 compressed minivan sized bundles of vines from the front and rear yards (and have recuperated from same) it’s time to get back to finishing the resurfacing of the back deck, benches and build the new stair sets. I’ve delayed finishing this deck project for too long.🙄🫣🙄
After finally getting three reputable quotes we’re having the polybutylene plumbing that was originally installed when our home was built replaced before the end of the month! Boy are Plumbers proud of their work! (They have every right to be considering how involved this actually is to accomplish!) I had been seriously considering doing it myself but when actually laying out the work to be done in the locations it needed to be done within and iven my limited dexterity nowadays I thought better of it. The professional licensed referenced staffed plumber we selected is capable of getting the complete job done including the finished drywall work done in one to two days for a 2 full bath, 1 half bath, kitchen, laundry room and three outside taps along with a new infeed valve w/ new ground box. This is a sizable fraction of the time by an order of magnitude it would have required me to do the same work. Plus being done by licensed experienced plumbers who have done similar work dozens of times they will know what to do that isn’t readily apparent to someone like me until things get opened up. The extra bonus is my homeowners insurance company is gonna be happier with the professional plumber as well. Fingers crossed but it should be well worth the investment.
We also finally got three valid reputable quotes in for getting several of the most needed windows and doors replaced.
Wood trim/frame windows and exterior doors just have a really hard time holding up down here in the hot humid weather of SC.
This again is something I had been actively considering doing myself but again, getting the quotes from reputable companies changed my mind. They can get the right products installed with an experienced team in 1 to 2 days after the widows and doors arrive. This is a fraction of the time it would take me to do it myself. Also a lot safer for me given my limited dexterity nowadays. (Ahh…to be younger and stronger again…🤔🙄😂).
In both projects the actual cost/time/benefit/hassle analysis has come out in favor of having reputable contractors accomplish the work needing to be done. Older but wiser…..🙄🙄
Holding off on the kitchen renovations for now until the deck/bench/stairs, plumbing and windows & doors projects are finished….(and financial recovered from… gonna be a sizable but worthwhile dent in the bank vault :D :D to be sure)
Best Regards,
Over Easy 😎😎🐩🐈
I don’t get it :?
Even with the difference in tides and water flow, wide open throttle and hull speed both consume approximately the same MPG, with close to hull speed getting worse gas consumption. Are you sure your numbers are correct?
OverEasy
Post by OverEasy »
Hi NiceAft!
Good point!
Yes, this mileage aspect has me puzzled as well.
We have been getting some fairly high and low tidal ranges lately which means faster and stronger tidal flows.
I think that has something to do with it.
Also the direction of travel along the rivers comes into the analysis.
For a given engine setting:
Going downstream on a receding high tide would give a higher GPS ground speed…
Going upstream on a receding high tide would give a lower GPS ground speed…
Similarly going downstream or upstream on an incoming tide would give a different GPS ground speed…
The Beaufort River has a nominal 3 mph flow rate.
The tidal flow rate and duration varies by how high the tide was or will be and where in that cycle one finds one self.
Timing is everything.
I haven’t analyzed the limited data I collected vs the actual travel direction to fully understand what I observed in any depth…(as yet).
Then there is the route aspect…the estuaries, rivers, creeks around here in SC are anything but straight for the most part.
The twists and turns affect how the GPS calculates the ground speed to some extent as well (but not by much as it’s something of an near instantaneous reading to be honest).
More trips…more data.
What I was doing on these extended day trips trips where I measured fuel consumption for a particular tank of fuel was to try and maintain a consistent GPS ground speed of 15 mph for a tank and 7 mph for a tank… so the rpm was somewhat more variable while the ground speed was more steadier.
We did this speed control in mind to better understand what we could anticipate on extended trips where we will need/want to get to a specific place at a particular time with an anticipated fuel consumption and reserve amount.
What this all points out is that boating is multidimensional and has multiple variable at play at any given time… so we are looking for empirical data driven “Rules of Thumb” applicable to our vessel and travel needs.
I figure that we will be more apt to be traveling for extended periods of time at lower GPS ground speeds on our extended trips for the most part. By setting our pace based on the GPS ground speed rather than on engine rpm setting we’re more apt to meet our travel window expectations… we prefer to arrive at destinations during daylight if and when possible. Nor do we want to zip along unnecessarily and miss out on what sights there are to see along the way to getting there…
Having at least a general expectation of a 100 mile range and a 68 to 80 mile fuel reserve is something we can work with for now.
Longer trips further afield will of course require more detailed refined data, anticipated water flow conditions and specific trip planning.
What’s good to know at this point in time is that we can reasonably plan on being capable of getting from our slip in Port Royal/Beaufort to Charleston/Fort Sumpter (approximately 101 route miles away well within our 24 gallon onboard fuel capacity.
(Now traveling the 60+ miles from Florida to the Bahamas is a different sorta thing altogether 🙄🙄… doubt the Admiral would be game for that much open water… me neither to be honest :D :D but it’s nice to know that Over Easy could be capable of it 😉).
Best Regards,
Over Easy 😎😎🐩🐈
The reports I have read on trips to the Bahamas, seem to report that at the point where the warm waters of the Gulf Stream meet the cooler waters of the Atlantic, it gets rough.
As for the gas mileage; two years ago on our cruise to the Chesapeake from Philadelphia, on our initial leg of approximate 50 miles down the Delaware River to Delaware City Marina, Delaware, produced terrible gas consumption. Although going downstream, we were ploughing against an incoming tide.
If my memory serves me correctly, on the second leg of the trip (at hull speed), going to Havre de Grace, MD, the 35 mile trip (again, if I remember) only consumed 4 - 4.5 gallons.
OverEasy
Post by OverEasy »
Hi All!
Just had a great weekend of watching the Navy Blue Angels Airshow! Both on land at the Marine Corp Air Station here in Beaufort SC Saturday and while on Over Easy on Sunday. (As a bonus our daughter came for a visit and was able to join us on Sunday! 8) 8)).
Near perfect weather both days!
Here are a couple pictures taken from the boat:
Best Regards,
Over Easy😎😎🐩🐈
OverEasy
Post by OverEasy »
Hi All!
We’ve been fortunate to have been able to get out an average of 2 to 3 times a week for day trips from our slip to cruise the local estuaries. Enjoying ones we have become familiar and discovering new ones as well. That the great thing about our Mac26X… it’s shallow draft, good sized engine and swing keel provides us with so much flexibility!
We’re using Over Easy again this year in “Trawler” mode. It’s what works best for us, especially with the various smaller estuaries here around Beaufort SC that we so enjoy exploring. (The mast, boom, rigging and sails are safely stored and after we get our house projects sorted and completed we’ll be get back to the sailing part. 8) 8) ) Below 6 knots we deploy the keel about 50% of the lift line travel to act as a pseudo skeg to help with maneuvering and improve cross wind stability. It helps a lot in tight channels and the narrow estuaries as well as in maneuvering around the marinas and docks. At this position the swing keel is at the depth of our engine or slightly below it. So in addition to our depth sounder it acts as a warning in the shallows… if the lift rope goes slack it’s time to stop (lifting it up BEFORE 🙄 reversing). It really does help by providing a hydrodynamic reference and pivot.
Yesterday, May 12, the Admiral, Mac🐩 & I had a really nice time circling Paris Island! 😎😎🐩
Saw lots of pretty shore lines, several dolphins and even big sea turtles 🐢 too! After completing our loop in about 7 hours we continued on to the public dock in Beaufort and had a nice supper at Panini’s before going back to our slip in Port Royal landing in the dark. It was a really nice day on the waterways.
The fuel efficiency of our new Suzuki DF60AV is remarkable (verging on astounding) for us in comparison to our old Tohatsu 50! All of yesterday’s cruising was accomplished on well less than one tank with lots to spare. Power settings were roughly 50/50 with half at 6 knots and the other half at WOT. (We’ll refuel before we head back out again today to get a specific gallonage to include later.) Suffice to say we are very satisfied (ecstatic 👍👍) with our new engine. When completing a similar trip in 2021 with the Tohatsu we used nearly both 12 gallon fuel tanks! Big improvement!🥰🥰
Sorry 😞, no pictures as we were having such a nice relaxing time of it we plum forgot to take them. We’ll try and do better on today’s excursion.
On the SC house project front we’ve made some limited progress by getting the plumbing redone by having all the old Polybutylene tubing removed and replaced with new PEX tubing … while they were at it we had all the 30+ year old original sink faucets and shower assemblies replaced as they would have all the relevant walls opened up anyway … WHAT A TASK!!! Definitely glad we had it done professionally! While I had seriously contemplated doing it myself it would have taken A LOT longer than the one day a crew of 6 professionals accomplished it in. They even completed all the necessary drywall repairs the following day perfectly 👍👍 Well worth the cost!
As mentioned previously we’ve gotten several quotes for the various windows and doors that need replacing and selected a vendor. Now the challenge is getting the finances in hand to place the order and scheduling the work to be done. Again, this is something we have chosen to have done as doing it ourselves really would simply take too long and a professional crew will get the removal/installation work done in a day. Then another day or two for the drywall repairs. For us the time/cost benefit really goes with having the professionals do it.
Best Regards to All
Over Easy 😎😎🐩🐈
OverEasy
Post by OverEasy »
Hi All!
Our loop around Paris Island was 51 statuary miles plus the extra excursion for dinner in Beaufort was an additional 8 miles for a total of 59 miles.
The following day we found the gas dock crowded so, given we still had plenty of fuel in the Port tank and a full Starboard tank we skipped the refuel and headed up the Beaufort River to Brickyard Landing then turned to Port to explore McCalley’s Creek estuaries logging an additional 26 miles on our Port Tank. Total mileage on the Port Tank came to 85 miles with a roughly 50/50 power setting of 2000 rpm (7 mph) and WOT 5400 rpm (17 mph) that consumed 13 gallons even that gave us about 6.5 mpg.
Given we have 2 tanks at a nominal 12 gallons each (13 gallons each if we decrease the tank air gap space) can provide us with roughly 156 mile range. (Further if we take advantage of the tank air gap 2 gallons = 13 miles). That shoul enable us to make the 101 mile distance from here to Charleston with fuel on board. Two days up/three days in Charleston/two days back home. A nice week long trip. So now we have to get the ICW guides out and start making reservations.😎😎 Earliest we can look at doing this seems to be August/September….. We’ll just have to see how things work out with the other projects and commitments 🙄🙄.
Best Regards,
Over Easy 😎😎🐩🐈
OverEasy
Post by OverEasy »
Hi All!
Another Great Day out on the water Sunday!
Bright sunshine, nice breezes and open waterways.
Three days in a row!😎😎
Here are a few pictures to enjoy:
Late in the afternoon Sunday the weatherforcast here in the South proved itself to a tad bit inaccurate as we approached Brickyard Landing! Thunderheads ahead! Thunderheads to Port! Thunderheads to Starboard! Time to turn and “RUNAWAY RUNAWAY RUNAWAY” as Monty Python once famously said! Glad we have our new Suzuki engine! It turned on a dime and allowed us to turn tail and make run for home and out of harms way. We got out from under the weather and arrived back at our slip before sunset and enjoyed a pair of cold Strongbow Hard Ciders after giving Over Easy a freshwater rinse and engine flush.
What a nice weekend!
Best Regards,
Over Easy 😎😎🐩🐈
