Mac 26S Center of Gravity
Does anyone know where the center of gravity is on the Mac 26S with the water ballast full? I’m putting my boat on a lift and I’d like to keep the center of gravity close to the center of the lift.
trswem
- Sailboat: MacGregor 26D
Re: Mac 26S Center of Gravity
I think if you find the center point of the water line that's going to be close enough. These are light boats.
- Stickinthemud57
I would say a little bit forward of the axle when on the trailer, probably no further forward than the mast step.
Here's a link to a photo if helpful.
http://highlifeyachts.com/photos/fullsi ... fers-1.jpg
Thanks. This is where I ended up putting it. I wasn’t sure if the water ballast changed the center of gravity from where it is on trailer.
- Stickinthemud57
Are you emptying the ballast when it's on the lift?
