Replacing my ballast gate valve
Shane anthony
- LordElsinore
- Location: Salt Lake City, UT - "As You Wish" - Suzuki DF60A
Re: Replacing my ballast gate valve
BWY sells this one:
https://shop.bwyachts.com/product-p/h210-1v0.htm
They also sell these seals:
https://shop.bwyachts.com/product-p/h208-1v0.htm
I've not done a replacement on my boat yet, but I do have an electric valve that I am hoping to replace mine with later this year
Shane anthony
Thanks for the info! I looked on BWY site first don’t know how I missed it. I’ll have to check out the electric valve, is it just convenience or other reasons?LordElsinore wrote: ↑Tue Aug 06, 2024 12:08 pm BWY sells this one:
DaveC426913
Safety is another one. Lifting the set and bending over the transom of the boat is something to be avoided if possible.
MacX 2000 Honda BF50A 'SeaSaw'
- LordElsinore
Safety and convenience. I typically sail alone and there are times when I'm reaching back over the seat while at high speed to close the valve (after emptying ballast when I'm about to head to the ramp to pull the boat out on the trailer). Even with the extension handle added and my autopilot enabled, it's precarious
The one I got looks something like this:
I can't recommend it yet because I haven't put it on. Just had it in the box after buying it a couple years ago when it was on sale. It's going to require some holes or clever routing for some wires
- Be Free
I've lost a pair of prescription sunglasses and a cell phone leaning over to close the valve. I think I've learned my lesson. Time will tell.DaveC426913 wrote: ↑Wed Aug 07, 2024 3:34 pmSafety is another one. Lifting the set and bending over the transom of the boat is something to be avoided if possible.
Maybe I should get one.
Bill
2001 26X Simple Interest
Honda BF40D
Honda BF40D
- kurz
I connected the handle of the valve with a long wooden stick, so I can open/close from the helm seat.
We should support BWY as they are our ONLY authorized Mac parts dealer and we want to keep them in business.
However, many of the Mac parts are easily sourced. I believe the gate valve is a standard RV valve
https://www.amazon.com/Valterra-T40-Spi ... B00594AZRU
If you wanted to upgrade to one with a remote handle.
https://www.amazon.com/Camco-Waste-Valv ... BQR1W?th=1
- LordElsinore
Ha ha I have that remote handle one sitting in a box right next to the electric one
Part of the reason I haven't installed either yet - trying to decide which I should try. When I viewed your Amazon link from my Amazon account, I see:
Last purchased Apr 11, 2023
Well, tell us how your replacement works.
My gate valve must be leaking. We launched the boat and put her in the slip and went home. Gate valve closed etc.
We were unable to get back to the boat for weeks and when I went to put the ballast in.....it was FULL.
So I'm thinking it needs replacement. That extended handle diddy looks interesting. I may have to try it.
- NiceAft
I keep a boat hook just inside the companionway, and use it to hook and open the valve, and push down to close the afore mentioned valve
Ray ~~_/)~~
That's how I do it as well. And only 2 times a year. Open/fill Open/drain.
For $5 more if I'm replacing it anyway, that extended cable might save me leaning over to "hook" the valve stem.
The electric version LESM has is interesting because....I'm a geek.
- kurz
I don't know if this remote kit will last long on a Mac. Think about salt water, all time a year in the weather...
So my wooden stick does the job for 10years now. It is connected to the original handle down and goes up over the helm seat.
Also love my remote handle for the motor disconnect. I just open the helm seat to go swimming...
DaveC426913
This is what I really want.
I had it all designed and everything with a sliding positive lock mechanism, controlled by a cable in the handle.
I balked at installing it though, because it required permanently modifying the existing jouint by grinding down the raised bolt.
I would love to see your design.
(On the other hand, I am reconsidering the safety issue. Based on my sailing style, I like to have my motor readily available if it is needed.)
- kurz
This configurationn has worked now for many years perfectly.
This was the first handle. I lost it while trailering.
So the second one, I have secured with a cord.
Easy breasy...
Also you can see in the back the wooden remote handle for the ballast valve.
