Upgraded blue water rudder brackets?
Ixneigh
Post by Ixneigh »
Mine have the bend in them but otherwise seem to be holding up. Is it worth upgrading to the heavier ones?
Do plan on maybe an extended trip to the Bahamas.
Thanks
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
kurz
Re: Upgraded blue water rudder brackets?
Post by kurz »
Yes, my :macm: 2011 had the small ones.
with the heavier it is much better!
Ixneigh
Post by Ixneigh »
I have a 2011 also. I’ll pick a set up. Thanks.
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
March
Post by March »
Can't hurt. We keep a spare pair in the bilge and they truly came in handy in the Bahamas. One morning, the water was so incredibly transparent, that we forgot to keep a keen eye on the depth. At some point, while sailing serenely, the boat got stuck in the shallows and ended up teetering on three points: the centerboard and the two rudders. All of a sudden it became apparent that the current was pretty strong. By the time I jumped into the waist-deep water and sliced the rudders' ropes (we could not pull them up by hand anymore), one of the aluminum brackets was already bent and cracked. Luckily we had a spare and we replaced it later in the day. No biggie
March wrote: Wed Jan 29, 2025 2:19 pmLuckily we had a spare and we replaced it later in the day. No biggie
How difficult is it to replace the brackets? Can it be done in the water?
Ixneigh
Post by Ixneigh »
I don’t think it would be possible for me to do
It alone. But if I had the part at least that’s something. I could always try to enlist other cruisers assistance. Re: Gin Clear water. Oh how I miss that!! Been too too long.
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
Jimmyt
Post by Jimmyt »
Ixneigh wrote: Thu Jan 30, 2025 5:28 am I don’t think it would be possible for me to do
Ix
Plus, the bracket bolts are well below the waterline. So, it will be exciting to do in the water on an M. Not sure about the X.
Jimmyt
P-Cub-Boo
tuxonpup
Post by tuxonpup »
OG 26X aluminum rudder brackets were above the water line, everything transom-mounted was at the deck's edge;
rudder bracket : ladder pivot : motor bracket : valve handle : rudder bracket
1996 Macgregor 26X w/150% RF Genoa & Nissan 50hp 2-stroke
Jimmyt
Post by Jimmyt »
I think that’s better than the M…
Jimmyt
P-Cub-Boo
Ixneigh
Post by Ixneigh »
You have to do it on the tide with the M. You have to unbolt the lower gudgions, 4 bolts. Impossible to do alone. Plus reseal with marine sealant.
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
At the beginning of the 2024 season, my son unbolted the "wrong" safety pin on the rudder brackets. After launching, we soon learned the rudders would not go down. I didn't want to pull the boat, so switching the bolts IN WATER was a challenge.
The X brackets do seem smarter and above the waterline.
This thread reminded me of Madd Mike.
For awhile, he was thinking about taking Xenons Arrow across the Pacific for a trip to Hawaii. He mentioned that the rudders would need some reinforcements
Chinook has posted this: " I remember some of his last posts were talking about trying to sail his boat out to Hawaii, but I don't think he ever made that trip. While he was active on this site, it was always fascinating to read his posts."
Ray ~~_/)~~
March
Post by March »
If memory serves, the aluminum brackets that cracked and bent were simply held in place by a vertical axle. We didn't have to remove the plate that goes against the fiberglass wall. That was still in good condition. It could be done easily in waist-deep water. Not hard at all.
(It was definitely easier than removing the centerboard while on the water, in order to clamp it back together, having split it by hitting a rock that lurked unexpectedly in the middle of the Nassau canal, on an earlier occasion)
kurz
Post by kurz »
March wrote: Fri Jan 31, 2025 8:54 am If memory serves, the aluminum brackets that cracked and bent were simply held in place by a vertical axle. We didn't have to remove the plate that goes against the fiberglass wall. That was still in good condition. It could be done easily in waist-deep water. Not hard at all.
U talk about :macx:?!
March
Post by March »
That is correct. It's an X. The aluminum brackets look like those in Tuxonpup's pics
