Chumpy36 wrote: ↑Tue Feb 25, 2025 4:27 pm
Can y'all help me how to rig my boom tent? I rigged it up today quickly (I had to make it to a meeting) but it's not great. I suspect I need some new lines and some good clips. But where is best to attach the get the most protection?
Sometimes I have my boom tent over the siding hatch (like in your picture), sometimes it is over the cockpit, sometimes I rig two tents and cover both. It depends on the weather and what I'm trying to accomplish. I suspect you may find yourself rigging in similar ways.
Your goal is to connect the front corners of the tent to any convenient point forward of where you want the tent to be and the back corners to a similar point aft of where the tent should be. You want the sides of the tent to be in tension so that water will run off the tent evenly and not gather somewhere in the middle of the tent. It does not have to be extremely tight, but you don't want it to sag and collect water.
It looks like the lines are permanently attached to the tent. You can leave them attached and just extend the connections with additional lines or you can replace them. Whether you replace or extend the existing lines you can make the length of those lines adjustable with something like an adjustable grip hitch (what I learned in Boy Scouts as a "taught line hitch").
You may find it convenient to attach your lines to the lifeline. In that case you can use something like the Prussick knot to create a loop that you can slide to an appropriate spot anywhere on the lifeline. A square (reef) knot is fine for making the loop or you can use a fancier knot or even splice the line you use for the Prussik into a loop.
