Got a new problem I can't seem to figure out. The centerboard will not go all the way into the hull. It hangs about two foot out.
You cannot put any more force on the line. It will not go up. It comes to a hard stop and that's all it will go.
I jacked up the boat and removed the trailer. The rope / line was the wire-to-double-braid-rope style. I could see no places it was catchingor fraying.
There are no catches or sticky points in the centerboard to centerboard trunk. It goes all the way up by hand without any problems.
I replaced the line anyway with solid braid and then again with double braid. No change with either.
I propped the centerboard all the way up w a ratchet strap, tied off the rope, then removed ratchet strap. The centerboard still comes down about a foot. Here is a picture:
Please note, this picture was taken after propping up the centerboard by hand and supporting it, tightening the rope, and then removing the support. The centerboard touches the ground when only pulled up by hand.
Thoughts? Help?
