Yes, and a Mercedes is cheaper than a gold plated Chevy. I personally see no necessity to mount a flooded cell battery in a box or to provide venting. The amount of hydrogen vented by a properly charged battery is miniscule and dissapates immediately. Even if I did, unless the AGM or gel batteries you buy are way cheaper or the battery boxes way more expensive than what I have seen, the numbers don't add up as you say they do. Plus, you're still ignoring the charger issue when it comes to cost.Robert wrote:The AGM is less expensive and more compact than the combination of a Wet Cell battery and the proper mounting box even without accomodating overboard venting.
Your conclusion doesn't follow, and it's simply not true according to those who seem to know more about it than you. I don't claim to be an expert. I'm quoting others whom I believe have no particular reason to make things up.Robert wrote:I use AGM batteries in my car, they are sold for automotive use, they must be able to accept wet cell charging.
We don't really know whether you've been doing things right or have just been lucky. I'll give you the benefit of the doubt. The manual for my charger says it's to be used for flooded cell batteries only. If you're saying I should ignore what's in the manual based on your experience, no thanks.Robert wrote:I used AGM batteries exclusively in my Mac26X with excellent results. Charging for the starting AGM was from the Suzuki DF50. Charging for the house AGM was using a three stage regulated charger whch had battery charging smarts in it. This charger could charge 30Amps rate. The charger was selected as a regulted type that could be used to operate the house loads even without a battery, it was a type used often in the solar house power world. This charger was not AGM specific, but worked very well. There is a 70Amp model which I would select if I had it to do over. The charger will not overcharge the battery, that is a standard feature on most battery chargers. If there is no built in overcharge protection the charger should not be left un-attended.
Honestly, I was waffling as to whether my next set of batteries would be AGM or gel, until I found out I'd need an expensive new charger as well.
You can call it whatever you like, that doesn't make it so. Your statements conflict with those from West Marine.Robert wrote:You cannot charge AGMs over 14.2V since that would take an enormous amount of current to overcome (pull a voltage drop accross) the low internal resistance. Instead the charging voltage will be limited by the AGM battery. I call this inherently safe charging.
Ditto.Robert wrote:It would take a huge overcharge to force gasses out of an AGM battery. Remember that the AGM has space right next to the lead plates to retain all the gasses normally going into and out of solution. Also remember that the AGM battery will not heat up much at all when charging. AGM is much safer to have on a boat since the accumulation of hydrogen gas from wet cell batteries in the enclosed bilge or cabin might present an explosion hazard.
Why would I want to try such a thing, and what possible relevence does this have to use in a Mac? I don't intend to take the batteries out of my boat until I have to replace them. With reasonable care, I'm not worried about acid burns or damage to my clothing.Robert wrote:When there was a power blackout in my area, I used one AGM battery to power the VCR/DVD and TV for the kids in the house. They could watch a movie or two, then I would switch it over to just TV and catch the news while also running the aquarium life support for the fish. After a long night the AGM would be down to around 11V. Next morning I would carry the 70lb. AGM to work and charge it while I worked. Try carrying a wet cell battery to and from work under your arm for a week and see how many of your clothes get acid holes.
You're just making stuff up to test me, right? I've had not one but two buckets of acid in my bilge evaporating and outgassing for four years, and have yet to notice acid fume damage. An occasional splash with salt water, now that I'm concerned about.Robert wrote:How about this reason to use an AGM in the Mac26X: Do you want to store stuff in the bilge storage provided in the Mac26X? If you do and you have a bucket of acid evaporating/outgassing down there with your stuff, be prepared for acid fume damage.
Four years, haven't had any of this happen yet. I've had the rail in the water to the point water is coming into the cockpit, but no battery acid spilled. I haven't rolled the boat completely yet, and I don't intend to.Robert wrote:How about when you do battery maintenance and knock off that crusty stuff on the wet cell terminals, or overfill it, or have acid spill out when the boat is healed over then end up washing down your bilge with baking soda to neutralize the acidy mess?
Every price I've seen, the AGM and gels are nearly 100% more.Robert wrote:Having the dangers of a vented to the cabin bucket of acid in a Mac26X is not warranted when for a few dollars more (40% more usually) you can be far safer.
Which battery would you rather sleep nest to? A leaky bucket of acid wet cell? Or a nice clean can be mounted on its side and shipped UPS AGM battery?
Nearly everything connected with boating is dangerous to some degree. I've been living with this particular level of dangerousness for four years, I haven't lost any sleep, and I will probably do it for many more.
I'm 54 years old, I have been buying batteries since I was 18, and although I admit there is some convenience involved, I have yet to hit the necessity to have a battery shipped. Stores in my area have batteries. Go to the store, buy a battery. Not too tough.
The idea that you might mount a battery on its side is interesting but irrelevant.
You and some others think it's worth it. I and some others don't. You can consider us misguided if you want. The feeling is mutual. We all look at the same set of "facts," some of dubious validity, and a whole lot of opinion, and come to different conclusions.Robert wrote:I figure the AGM is worth a lot more than the slight extra cost...
Not surprising. None of us can be "proven" right or wrong in our conclusions, and either position is valid. This doesn't have to be a debate in which we pick opposing positions and can't concede any of the points of the other guy.
