Help!!
des uk
Help!!
Post by des uk »
:cry: Woke up this morning to find dark yellow/orange spots all over my Mac 26X. Used cuting paste but it didn't budge. Don't know what the hull the stuff is but it's like those marks you get if you leave iron fillings on the gel coat for weeks. Marks only arrived after light rain and are imbedded in the gel coat all over the decks incl anti slip surfaces where it is worse. What can i do to get this cleaned off. Boat is stored in-land and was pressure washed only a week ago in prep to sail next week.
Des UK
Sticky leaves Im guessing.
Pressure washer should take it off though????
Sloop John B
Post by Sloop John B »
Del, I was crawling around under my boat (checking trailer) and came across one inexplicable spot similar to what you describe, about as big as a hand print. Boat was wet with morning condensation and the spot rubbed off.
Sounds like your discoloration is in the gel coat itself. Oak leaves will tarnish but blasts off with pressure washer or even soap.
Might be a manufacturing defect, but Ive never heard of such. Youll probably have to coax one of your mad scientist friends over for a look.
Being in the UK certainly doesnt help for any recourse you might have with MacGregor. Do report the situation to your dealer (if you have one).
Let us know what you find out.
Zoran
Post by Zoran »
Blue gel FSR (Fiberglass Stain Remover) is available in all marine stores, at least in Vancouver. Just brush it on and rinse it off, works like a charm. Tested and true.
Zoran
LOUIS B HOLUB
Post by LOUIS B HOLUB »
I had leaf and blue berry and bird poop stains after one week of storing my boat under a blueberry tree.
Solution: A small "hand held" 16 oz. spray bottle with a mixture of water, plus/minus 4 tablespoons liquid soap, and about 4 tablespoons of bleach. Mist the spots, with a hand scrub brush lightly, then rinse.
I followed up with a wash/wax automobile soap solution, and the boat looks great.
Storing the Mac under a tree is a NO NO. (Unless it is tarped).
RandyMoon
Location: Rockwall, TX Lake Ray Hubbard 2005M #0690 L405 Tohatsu TLDI 90 (Rhapsody in Blue)
Post by RandyMoon »
I learned the hard way not to leave the vents closed on my gas tanks during hot weather. Gas seeps out and leaves nasty orange stains. Not easy to remove.
