Hi all.
Replaced the upper shrouds - made to the EXACT length of the old ones and slightly heavier grade s/steel wire.
Looking up the mainsail slug groove, it bends to starboard near the top. I have the backstay tight and the frontstay turnbuckled tight.
Have I got the whole rig TOO tight?
having the Mac backstay to starboard, does this give the top of the mast a 'natural' bend to starboard?
Thanks in advance.
Max
Mast Bend to Starboard
- MAC26X
If you release any backstay tension the mast should be straight. If it leans near the top, the upper shroud is tighter on that side.
http://www3.telus.net/harbro/tuning.htm
and
http://bbs.trailersailor.com/forums/art ... es/read/92
are good standby guides if you haven't read them yet.
Good luck.
and
Good luck.
