Pics of s.s. spreaders
Sassy Too
Post by Sassy Too »
James V ....Good afternoon,here are some pics I took this morning.These are the best I can do untill I drop the mast.Hope they help! Happy Sailing.....DonImageImageImageImage
Scott
Post by Scott »
Cant see the pics
On Edit, Can now.
SURV69
INTERESTING
Post by SURV69 »
I was always under the impression that speaders on the Macs had to be flexible at the mast.
If I see it right, you have solid/non-flexible spreaders(that is no movement at the mast).
I really like the idea, but would love to see a arger pic of the actual attachment to the mast.
BTW, is this a toally home-grown setup? :wink:
DLT
Post by DLT »
I think this is really close to stock.
I have what looks like the exact same setup. The only difference is that my stock spreaders (the tubes themselves) are Aluminum.
The mast mounting bracket, even stock, is stainless. It mounts to the mast such that it pivots about the mast. Or, said more correctly, the bracket and spreaders are stationary, with respect to the boat, while the mast rotates with respect to the boat and the spreaders, etc....
Sassy Too
Trying
Post by Sassy Too »
surv69...Try this picture .They do pivot together, where they connect at the mast.Image
mtc
Location: Panama City Beach, Florida 05 M 'Bellaroo' 60hp Merc BF
SS spreaders
Post by mtc »
I've replaced the Al spreaders with SS and am very pleased. Went with the same dimensions and mounting, though am considering quick pins in place of the bolts so they can be removed when the mast comes down.
Anyone replaced the bolts with ball-lock quick pins? Not something to use on the forestay, but should be ok on the spreaders. The force under sail would be towards the centerline of the mast forcing the spreaders into their mounts, so dislodging shouldn't be an issue.
Michael
Sassy Too
S.S. Spreaders
Post by Sassy Too »
Good morning Michael.......I'm not sure about the pins that you are looking for,but the type I used are working Great! I always put the "Bail" aft,so it is protected by the spreader.However,I don't see that the Jib would ever come in contact with them.I didn't check if these are available in S.S.,but Lowes and H.D. have them in stock.If you increase the size of the last picture I posted,you can see the pin better.When I lower the mast,I put the pins back in the spreader mount,and bungee the spreaders to the mast along with the Furler. Hope this helps....Happy sailing,Don
mtc
Post by mtc »
Ah, yes, I see them now. Are they SS? This is the type pin I'm using to connect my engine steering to the rudder arm. Not SS either, but hasen't rusted yet - yet. At least I'm confident that it's not coming out.
A lot less $$ than the quick pin, which should be around $25 - $30.
Did you change the length of the replacement SS spreaders from stock?
Michael
Sassy Too
S.S. Spreaders
Post by Sassy Too »
Michael.....No,I did not change any of the dimensions,just material and hardware. Don
mtc
Post by mtc »
Thanks. I'll check out those pins.
