Traveler Track upgrade
Only if the dock would let you keep the nose straight into the wind... This is critical.KEVIN'S OWN wrote:Would it have been better to have tied up to a dock and tried to raise the sail? From what you mentioned I guess so as we would have been stationery.
I've lost a few of those. They don't float! When I run out I wrap a bungee around the mast below the slugs to hold them in. On my Mac 25 I drilled through the track horizontally side to side and used a hair pin cotter pin. Quicker to put in and it stays put.I lost my first sail stopper, and then attached it to a 1' long 1/8" piece of cable from the hardware store.
My boat came from Bill at Boats4sail and just about everything has fool proof safety . Quick clips and every other this and that all SS and my sail stop came with a SS lanyard so it will never come up missing. I tell Ya that Bill is one clever guy . . . .baldbaby2000 wrote:I've lost a few of those. They don't float! When I run out I wrap a bungee around the mast below the slugs to hold them in. On my Mac 25 I drilled through the track horizontally side to side and used a hair pin cotter pin. Quicker to put in and it stays put.I lost my first sail stopper, and then attached it to a 1' long 1/8" piece of cable from the hardware store.
