I just went thru this process ... two weeks in SoCal waters shouldn't be a problem ....
except you'll need to hire Terry to scrub it when it comes out!
Seriously, even if the trailer work stretches out to a month you should still be okay. But if you plan frequent dunks like that, I think the epoxy might make the cleanup easier, or at least less damaging to the gelcoat. And of course, it should prevent blisters even of the layup was defective.
Finally, I suggest a half-hour long dash (with all 90 horses) on the day you plan to retrieve it. Then, get the rig directly to a quarter carwash immediately after it's pulled, don't pass GO. When it's fresh the light scum layer should blast off quite easily. But if you let it dry out, be prepared ...
(to call Terry~!).
