The early 26X had dual ballast fill valves, a small gate valve at the port transom plus the center valve that pclark describes w/ a rubber backed plate" - the ballast tank air vent is under the step as part of the same assembly.Maccpt wrote:Would someone please explain this "rubber backed plate"... I am not aware of one...
Sometime in mid-year 1998 (model year) the transom gate valve was enlarged and moved to starboard, the center valve behind the CB trunk was discontinued, and the ballast vent was moved under the v-berth. The forward vent was better suited to fully exhausting any air bubble from the ballast tank. Later in '98 or '99 Roger was able to revise the interior liner and eliminate the step for the center ballast valve.
I believe some owners of the early model use both valves for filling or emptying the tank since the transom gate valve was only 1.5" versus 3" after 1998.
