Honda 50 Prop -- Solas Amita 4-Blade
- PeteC
Does anyone have actual experience with the Solas Amita 4-Blade Prop, part 3313-118-09?
This is 11.8" in dia and 9" pitch.
I want to make sure it will work before ordering.
I had a bad expereince with a Michigan 4-blade, 12x9 prop. I assume the blade had too much cupping and it bogged the engine way down.
I currently run the Honda (Solas) 3-blade, 11.8x10 and it works well.
I am interested in the 4-blade for towing/skiing and for low speed performance.
- Terry
Solas Props
Pete;
I bought the Solas Alcup 4 X 11.4 X 10 and in hindsight realized it should have been the 4 X 11.8 X 9. Not all props are the stated pitch, in my case it bogged my engine down with the 10 pitch so I took it into a shop and had it pitched down to 9. When I picked it up the guy told me it was actually 10.5 pitch not the 10 that was stamped on it. After a test run I found the 9 too low as my revs were jumping well above 6000 so I took it back and had it repitched again to 9.75 which turned out perfect, put me at 5800. The pitch to rpm ratio is not linear as they claim in the powerboat world, 2" does does not equal 4000 rpm. Anyway I like the Alcup design over the Amita due to the medium cupping on the Alcup and you may prefer the cupping for towwing/skiing as it gets more grip/bite on the water. I would think the Solas Alcup 4x11.8x9 would work well on the Honda for your needs right out of the box.
One day when I have money to burn I'll get the SS Saturn prop.
PS The open hub/exhaust of the Solas props provide a good 5% increase in HP or so they claim.
- PeteC
Terry,
My concern is that the cupping may load the prop too much, just like the Michigan prop did. But based on your experience though, it would seem the Solas Alcup cupping must be less than the Michigan prop.
Also, if the 4 X 11.8 X 9 scales by prop swept area, then that would yield a 7% RPM reduction compared to a 11.4" diameter prop (with everything else being equal).
There seem to be so many variables that unless someone has run the exact same prop, it is hard to say the prop will work.
4 blades vs three
PeteC, In my opinion the 4 x 11.8 x 9 will provide nearly the same top RPMs and speed as your 3 blade by 11.8 diameter 10 pitch prop. When you add a blade, you reduce slip and the prop acts sort of like the next higher pitch.
The four blade prop will keep its grip better than 3 blades in rough seas and sharp turns. At idle or very slow speeds you will be able to feel that the four blade prop is smoother, ie the motor head will wiggle less and the whole boat seem calmer.
Do you still have the 4 x 12 x 9 MIWheel prop? I think if you repitched that one down to 8 pitch you would have a real nice towing prop. You can't expect much when towing with only 50hp, but having a tuned prop will help.
- Night Sailor
- vkmaynard
Prop
I have the same prop on the same motor as recommended by others. Big improvement in moving the MacGregor barge. Top speed is close to 18 MPH (as good as the three blade prop) while 4,000 RPM cruise and get-up-and-go is much better. Top RPM is about 5,800ish (redline 6,000). It could be depitched a little, but I have other things more important to attend to. We have two seasons of wakeboarding on the 4 blade prop; it would be difficult without the additional torque.
Victor
Victor
- PeteC
Re: Prop
Victor,vkmaynard wrote:I have the same prop on the same motor as recommended by others. Big improvement in moving the MacGregor barge. Top speed is close to 18 MPH (as good as the three blade prop) while 4,000 RPM cruise and get-up-and-go is much better. Top RPM is about 5,800ish (redline 6,000). It could be depitched a little, but I have other things more important to attend to. We have two seasons of wakeboarding on the 4 blade prop; it would be difficult without the additional torque.
Victor
Specifically, what prop do you have?
- vkmaynard
Honda Prop
I purchased the prop at Water World in Durham, NC (919-596-8185) for about $110. The part number is 58134-zv5-009ah, see:
honda.ca/marine/images/Eng/2005_Props/2005_BF40-50_Props_English.pdf
Victor
Victor
Pete C
It's a kind of late update to your question, but during some internet scanning today, I discovered that iBoats has the Solas Amita 4-blade props.
http://www.iboats.com/Marine_Store/dm/
I'm considering the Solas 4x13.25x13 for my Suzuki-60.
- kziadie
- Location: "Sundancer" 2006 26M Honda 50 MACM1338C606..... BAZS-3601239..... Central Chesapeake Bay
Mikebe,
Do you have the Alcup or Amita... I might be interested.
PS... I am the guy who passed you coming into the West River the weekend before memorial day. Pretty funny with the names, Sundancer and Raindancer.
Kelly
Kelly
"Sundancer"
2006 26M Honda 50
MACM1338C606
BAZS - 3601239
2006 26M Honda 50
MACM1338C606
BAZS - 3601239
