Not happy, I went back to the boat ramp, backed in, and installed the dog-eared 4 blade Michigan Wheel 12 in 10 pitch I'd gotten in but never tested. Oh man, what a difference. I noticed it right away, pulling out at idle. Smooth, moving a lot of water. Churning up mud from the bottom that I never saw with the three blade props. OK, this was looking good! I opened up the ballast valve and headed out, slowly inching up the throttle. By the time the GPS said 10 knot, the ballast was empty, and I inched the throttle on up, 11 knots, 12 knots, 14 knots...I started to see something I'd never seen before, massive walls of water sheeting away off the bow. The boat was CRUISING! People in other boats I were looking on in amazement. It was awesome. I've found the right prop for my boat. Not looking any further.
So I went back to my slip, and during the docking procedure, sat on my relatively new West Marine Aluminum boat hook as it lay across the cushions in the cockpit. I had just spent two weeks making a homade boat hook, with a heavily urethaned Ash handle and classic brass fitting, and had just told the admiral the day before that the homade boat hook really had no advantages over the 39 dollar aluminum one. Don't know if the homade one floats, it's heavier, etc. but it was more valuable because it was unique. Well, let me tell you, a wooden handled boat hook is a lot more DURABLE than the aluminum ones. The aluminum one I sat on folded like a pretzel. The wooden homade one is the one that got me home. Couldn't have had a better day.
Mod's note: 'conclusionary emphasis' added ~fc
