Problem emptying ballast?
I've owned my Mac26x for a few months and tried to empty the ballast the other day (on the water, traveling about 6 mph under motor). I opened both ends of the ballast (under the front cushions, and pulling the lever on the back - you can see I have all the sailing terminology down), and nothing drained. 20 minutes and nothing... I stopped at that point and just sailed, so I didn't get into really trying different things.
Anyone else ever have any problems?
LOUIS B HOLUB
- Duane Dunn, Allegro
I prefer to get up to a speed where the gate valve is clear of the water as it streams past the transom. Then it's real easy to see the huge stream of water shooting out the back. Once it slows to a trickle, close the gate valve and then the vent.
If you have an older X with the 2nd valve under the steps only open that for a faster fill (I don't even use it for this anymore). Keep it closed when draining the tank underway.
- Trouts Dream
I have a 97 X and someone on this board mentioned reversing to fill it faster and when it seems full, give a forward thrust to burb the tank then continue filling. You may look silly
backing around in a huge circle but man it works. Even at night there is no noticeable gurgling from an almost full tank. As for emptying I agree that you need to go fast enough to get the filling hole clear of the water and that usually brings the nose up.
- Sloop John B
For those who have been around a while, you'll remember I got myself 'beached' with nose slightly up. I drained the ballast while waiting for the tide to lift me away.
When I returned to the launch (recovery) ramp, gallons and gallons of water poured out.
I'm under the impression right now that I have to be cocked up considerably on the ramp to empty the tank.
If I'm pressured to leave the ramp early, I let the thing drain on the trailer while in the parking area. When I get home, I park on a slope with chucks behind the wheels to keep the rig from rolling backwards into the woods. I crank up the nose wheel and open the gate and a lot of water comes out.
In other words, if you're on the trailer and level , you are not going to get all the water out.
Underway, I think I might get the nose up enough to drain. Has anyone crawled back to take a look at the valve, is it clear or is it underwater?
Book says give it about five minutes or so; anyone get a chance to time it and realize it may take longer?
waternwaves
Yes, I always hang over the helm seat, at speed**, to view the gate valve while emptying ballast. With the boat at ~12 to 15 mph the gate valve is totally above the water's surface (as Duane wrote above) and the "fire hose" exit stream of ballast water is obvious. It's also obvious when the ballast exit stream has diminished to just a trickle, upon which I close the gate valve. I'd guess ~7 minutes, at speed, to drain the tank of late-model 26X with the 3-inch gate valve.Sloop John B wrote: . . .Has anyone crawled back to take a look at the valve, is it clear or is it underwater?
(just one opinion . . . 6 mph is too slow to empty the ballast tank ... min. 10 mph.)
** = CAVEAT EMPTOR . . . this "hanging-aft" maneuver isn't the safest Skipper's position in a speeding boat. I'm especially loathe to perform it when single-handing, since it requires hanging-aft while speeding forward. I have done it while alone, but I surely don't recommend it unless there's a qualified driver at the helm. CAVEAT EMPTOR!
