Teak Flooring?
Jimnkathy
Teak Flooring?
Post by Jimnkathy »
Does anyone know where to buy Teak flooring? I am looking for sheets of it that I can cut to fit my 26x. I am looking for the flooring with the white lines in it. ANy info would be greatly appreciated.
Thank you
Jim :macx:
Moe
Post by Moe »
The white strips are holly. The average Joe can't afford pure teak and holly flooring. Most of what you see, even in expensive boats like Pacific Seacraft, is a thin veneer of teak and holly on top of plywood. And even that's expensive. Google teak holly plywood and look for a source near you. It's really expensive to ship a single sheet. From what I've seen, almost doubles the cost.
You're talking about teak & holly plywood (holly is the white stripes), and you better have some cash on hand - it's expensive.
It generally comes in three thicknesses - 6mm (~5/16"), 12mm (~15/32") & 18mm (~11/16") - and a 4x8 sheet runs from around $190 for the thinnest to $250 for the thickest. For a Mac sole, I'd use the thinnest, and if you're very good with your measuring you can *just* do it with one sheet.
Google "teak & holly" "4 x 8" and you'll probably find a place in your area that has it.
Have a look at these links for more info:
http://macgregorsailors.com/cgi-bin/mod ... record=742
http://macgregorsailors.com/cgi-bin/mod ... record=434
http://macgregorsailors.com/cgi-bin/mod ... record=420
http://macgregorsailors.com/phpBB/viewtopic.php?t=6577
http://macgregorsailors.com/phpBB/viewtopic.php?t=1077
(BTW, I have a sheet in my garage... now if I can only get this leg healed so I can can make the floor!)
Divecoz
Post by Divecoz »
Not Cheaper , But maybe easier to work with and less costly to ship.
Near Zero Maintenance that's worth a bunch of Boat bucks and Sailing time.
http://www.ttcustommarine.citymax.com/p ... 753885.htm
Hmm... nice thought, but I'm sitting here doing the math...
It comes in 6' wide roll and is sold by the foot at $45/foot... and since the holly strips run linearly, that's probably around 5' you'll need... so we're talking $225 for a vinyl floor vs $190 for the real thing?
Easy choice for me. Gimmie real wood. Maintenance on a real T&H flooring is not much more than a once-yearly oiling. Not too bad.
Timm Miller
Teak and Holly flooring
Post by Timm Miller »
www.yukonlumber.com I got mine there for a 26X.......they have the pattern........you may need to trim for a perfect fit.........price in 2002 was about 120.00 w/shipping.
Randy McCotter
Location: Slave Lake Alberta Canada..... "Mari-Jacq"..... 2002 Mac 26X
Post by Randy McCotter »
well..... when you have a pattern for a 2002 26X, Sign me up and I'll gladly purchase it from you. I'm sure shipping won't be that much to Canada! (riiiiight)...... It'll be worth it I'm sure.
Thanks......... Randy. :macx:
