Sure its possible, and the math isn't difficult. But adding length also means adding wetted surface which means drag which means you need to loft more sail which means a proportionately larger sail area, which means larger mast, upsized rigging, stronger chainplates... It's not JUST the naval architecture that goes out of balance, its everything.seahouse wrote:I don't think this is so far out of reach for the person with the right knowledge base and technical skill (some on this forum, I would hazard to guess) and attention to details. All the basics to accomplish that are quite knowable - just apply already-known marine architecture principles.
A gaff rig _could_ make a lot of that simpler by not requiring any mast or rigging upsizing to loft more sail _and_ move the CE aft, and you _could_ replace the daggerboard with a glassed-in shoal keel to rebalance the CLP and helm. But then you're no longer able to power. Honestly I think you could get away with just a slightly longer and heavier daggerboard without any safety or significant performance issues. So suree, it's possible.
I've seen two Arkansas good-old-boys turn two Caprice Classics, one front-ended and the other rear-ended, into a single perfectly good car in two days, and that includes all the soldering of wires. They even made sure to pick two of the same color so they'd only have to paint over the ground smooth welds.
I think anyone who _could_ do the proper design work to lengthen a mac could also do the design work to just build a hull from scratch the length they want
And yes, I do need more room. The admiral has approved this boat for when we have a spare $200K sitting around: http://www.evolving-oceanis.com
So I'll be a Mac sailor for the foreseeable future
