Sorry, Rick
Posted: Tue Jul 22, 2008 8:08 pm
Sorry Rick, but I sure do NOT like your fix. If I understand, your new hanger is going to go across the top of the frame and be welded to the frame. Not good!
All the weight and shock loads will now be on the weld beads. It is far stronger to have the hanger below the frame, so that the frame is riding on the hanger and the weld beads are merely holding it in position.
Also, welding the hanger onto the frame with vertical welds will weaken the frame, possibly causing stress cracks later on. When putting a slice or patch on a beam, the only welds used should be parallel to the length of the beam.
If your going to have a welder come to you, he could weld the hanger under the frame where it should go anyway. If you are still going to put the hanger over the frame, at least put a large bolt thru the hanger touching the bottom of the frame so that the bolt will take the loads.
MHO
Ken
MHO
Ken
