Chip Hindes wrote:Wow, Dimitri. Maybe something to know how to do if theres absolutely no other way, but I'm serious when I say if I had to go through the drill you describe every time I wanted to beach the boat; I'd instead anchor in deep water 50 or 100 yards off shore and swim in.
Well Chip, to each his own.
I'll admit, 95% of the time I'm beaching, its because I'm not alone and so I don't singlehandedly beach which makes it a lot easier if someone is tending the bow anchor. This is something you can teach a passenger fairly quickly. When I'm singlehanding, I don't typically have a need for long walks on the beach as I am out to SAIL!
But really, there is nothing you can't do singlehandedly without the right planning. When I first got the Mac, I had some problem with tracking (used to a keel boat) and so even if I went out alone, I would call my wife on the cell phone and have her meet me at the dock to grab the bow as I was docking. I don't have to do that anymore either now that I've adapted my docking lines for this boat properly and gotten used to how she handles. It also helped alot by putting a wind indicator close to my dock so that I can see exactly what the wind is doing as I'm pulling in. You need to use the wind as your friend, not as your enemy. Boy, going from a heavy keel boat to a Mac, I sure looked like a real amateur the first couple times I tried some docking moves though.
If you read my story again, the first thing I say is that
conditions must permit. Frankly, if you have too much wind, too big waves, or too strong of a current, you should not be beaching there in the first place.
I have done that procedure by myself a few times...even with family on board..probably due to the fact that they are so busy trying to deal with bathing suits and sunscreen, they don't even hear me. So, the only rule I make is to clear the pathways so I can run forwards and backwards a couple times if need be. So, even with people on board, I've done it totally by myself before and yes, you can pay out some slack, estimate how long the rode should be, and then cleat it. You can then set the anchor with the engine. If it doesn't set, get out of there before its too late. You can always keep it in reverse and do a backwards turn out of there (downwind) so that you don't run over the rode. As for a crosswind, that is even more reason to have the bow anchor out there and under some tension, it will keep your bow pointed offshore even if you are going super slow. Hence why you should run it through the bow pulpit if you are going to try to do it from the cockpit...otherwise, when you lead the line back, your bow will turn towards the shore. Actually, cross currents are a lot harder to deal with IMO.
As for chucking anchors, I've been doing it for decades and yes, once in a great while it will foul, but then the worst thing that happens is that your stern will start to swing out downwind and you can either abort, or jump in the water and rescue the situation manually. I don't have any hesitation jumping out as long as the bow anchor is set properly. Again, its a very small Danforth that I use for the stern..maybe a 7 pound steel one that has a very fine chain that is probably only 6 feet or so long. Sure, I wouldn't use that as a primary anchor, but it always holds the stern to the beach. I coil up the chain with the anchor and then throw the whole mess together all as one. You have to use a little common sense of course.
BTW, there is another way to do it single handedly, kind of a modification of the Bahamian anchoring technique I think its called. But basically, keep both anchors with you in the cockpit and start a bow-to approach. Drop your bow anchor in (off of the stern), set it, drive up to the beach paying out rode, throw the stern anchor in off the side, then kill the engine, cleat the stern anchor, walk the bow anchor rode up to the bow turning the boat in the process, then cleat the bow anchor at the right distance to the shore. Obviously, something like this is not going to get you too close to the shore in anything but an onshore breeze but it may work for some. I used to do this quite a bit in power boats, but its a lot easier to do when you have an open powerboat. Still, not a bad technique in an onshore breeze when you are nervous about your primary anchor setting.
The key to single-handing is planning planning planning. Before you try anything, you must rehearse the procedure in your mind a few times..including contingencies and escape plans. Its good not to get too used to crew help for these sorts of things.
