Re: rudder alignment, starboard turns, search issues
Posted: Fri Jun 12, 2009 1:55 am
I'll take a guess. Perhaps the water pressure was greater on the outer surface of the rudders than the inner due to the engine pushing the water in between the two rudders, perhaps causing a bit of a vacuum. At 12 knots, this may explain the rudders bending, inward, especially since they're plastic. You're lucky they didn't break. I broke three IDA rudders to date, though granted, a custom (huge) size which is no longer being made. All breakages were under sail with motor tilted up. None involved grounding or collision, just pushing water. I now use stock rudders.
Leon
Leon
