DaveB wrote:The secret to any anchor holding power is the Chain. Use a min. of 15 ft. of 1/4 to 5/16 chain and have a swivel connection.
You can get along with less,
in certain circumstances, IMHO&E ... a kedge, a lunch-hook, maybe a second or third anchor. BUT - you will have to drop it carefully, with the chain led in the right direction, and set it
more carefully. I've got 30 feet of 5/16" proof-coil chain on my primary Raya Tempest (and 150 feet of 1/2" Yale Brait spliced to that), but Fortress suggested 6 feet of 3/8" beneath the nylon rode for my FX-11; and that has worked decently well for me, in the uses I specified above. (But I don't depend on it as my only hook, in a pinch.)
A Plow or Claw works good in hard and grassy bottoms, Danforth type excelent in mud or sand.
That's one virtue that I see in having at least one of each - you can use the anchor that best serves the anchoring ground.
The Fortress dosn't fit in anchor locker as the shaft is to long.it also wont fit on the anchor holder on bow pulpit .
My FX-11 is in a
"tube mount" on the transom of Bossa Nova. That short chain fits in there as well, and I've shackled it to the top of the tube ... the line rode is in a bag in one of the "fuel-tank pockets", and I connect it up if I see that I might want a "stern hook" to hand....
If you're keeping it as a "spare" you might want their anchor bag; it holds the Fortress very conveniently, and it comes with two right-size wrenches to fasten the fluke-shackles (plus a spare fluke-shackle and bolt, just in case).
The rest of your post shows you have the one part of an anchoring system that we can't buy:
Experience. We less-experienced sailors would do well to learn from you, even if we don't follow you exactly ...
