Re: Trailer re-assembly from container
Posted: Sun Oct 10, 2010 4:00 pm
Hi Phill,
It will fit into a 40ft container however it only has about an inch either side.
They didn't need to cut anything off the boat however they do need to remove the trailer lights, Guide Poles and mud guards as they are all too wide.
It is tricky to remove from the container as with the mast in place the height is probably less than 8 inches from the roof with the wheels and axels removed. This height restriction is difficult as even a trolley jack can't fit under the trailer chassis without the boat hitting the roof.
If I was doing it again I would have had some slimline dolly's ready that I could put under the frame, I came across a problem lowering the mast crutch but can't remember what it was. Ensure some thick carpet is draped down each side of the boat as mine had rubbing marks from the metal of the container on the blue hull.
Can I say too many times not to use Import a Boat?
Pete
Pete
