How to check noseweight
Re: How to check noseweight
Post by Kelly Hanson East »
I just measured my 2002 :macx: trailer at 16.5 to the jack, and 28 inches to the centre of the ball.
I think that makes it a 28 inch/197 inch = 14% increase, using the wheel centre as a fulcrum.
J.Teixeira
Post by J.Teixeira »
Remember to check the limit of the vertical weight (pressure) on the hook of the tow vehicle...
You may have surprises there...
Trouts Dream
Post by Trouts Dream »
Kelly Hanson East wrote:I just measured my 2002 :macx: trailer at 16.5 to the jack, and 28 inches to the centre of the ball.
14% DECREASE, further out lighter the load
“Give me a lever long enough, and a prop strong enough, I can single-handed move the world.”
Archimedes
DaveB
Post by DaveB »
There is also another point, having 10% of the total weight on the ball will give you much more traction in slime ramps.
Kelly Hanson East wrote:That 600# seems pretty heavy Curtiss. It will trailer fine, but it will be heavily loading the tow vehicle's shocks/springs. If you are towing short distances/under 50 mph I would let it be - if you are on long high speed runs, it might be worth thinking about it.
You have to have a lot of tilt on a single axle trailer to make a difference on the tongue weight.
There can be a significant difference between the jockey wheel weight and the weight at the ball. The difference will be roughly the ratio of the differences between the wheel/ball and the distance to the centre of rotation - without doing all the physics the axle will be a good approximation for this point. This could easily make the difference 100# or so.
The big safety issue for you folks with 120 kG tongue weight ratings (about 1/2 of the actual) is to make sure that your car can take this extra weight 'structurally' and that you arent going to break off the back of your car.
Trouts Dream
Unless its a front wheel drive. But who would tow with a front wheel drive? :wink:
thanks Trout
Threms
Post by Threms »
Trouts Dream wrote:Unless its a front wheel drive. But who would tow with a front wheel drive? :wink:
iwe got an BMW E46 330D, and its werry close to the road when riding whith the trailer, so i know the problem. It can be solved by spending som time when loading the boat. Goes from 15 cm. (5 inch) to 25 cm.( 8 inch)
But BMW is a backwheel drive, and im selling it to get 4x4, becourse last time i should take the boat up, it was low tide, and the ramp was a bit slippery under my backwheels. The whole thing almost ended in the water.
I ended up pulling the trailer the first 2 meters whith at rope, before i could back up at put it on the hook.
So here goes the BMW, :macm: comes first :P
Daniel
