Re: Electrical Issue...Update
Posted: Wed Jun 02, 2010 8:31 am
Okay, I'm totally lost now.Tom F. wrote:I found a white ground wire that was not atached to anything and was pretty sure it was not attached to the old fuse box. It has a slide on blade type connector. I have the green wire connected to the positive side of the new fuse box as it was in the old and a voltage tester indicates it is getting power. Itook the red wire that has an in-line 2 AMP fuse off of the negative side (again, as it was in the old) and put on the white wire that I found. The top two lights (instruments and water system) now work but the bottom one for the radio does not light. BTW the boat is a 2001 model.
You have 2 panels right?
The colors don't seem correct, but as mentioned who knows if the person who wired all this up adhered to standards.
At this point a good photo or picture might help figure out what's going on. The fact that you have power to some switches makes me believe the white wire is not what you think it is.
