To simplify things, set the rake
before setting the mast bend. The rake is still easily measured after mast bend using the bucket, or other method, by measuring from the top point and bottom point of the mast as if it were a straight line. If you're looking for 2 degrees of rake, you are looking at way more than 1 inch, which is really zero in our context here, I'm going to guess, without any numbers, that you want in the realm of 8 to 10 ". Get the mast height and plug it into the trigonometric ratio for the exact measurement. The tolerance is wide, so just get yourself in the ball park.
In the absence of a loos gauge, the method for stay tension in the following quote from a previous post might be technically the next best. On the hard, or on the water, if measuring from the common datum of the boot stripe your results should be similar...
Yipes! Tuning fractional rigging (especially with aft-swept spreaders) is like finishing drywall! If you keep looking closely enough you’ll never be finished.
To get all the details I would suggest a good book on rig tuning, because, I, as others might be, am generalizing, and “he who generalizes, generally lies”. I’m describing an “M” because I have the photo from the brochure, which shows the rigging, in front of me. So your results may vary.
In an “M” the mast rake is set by the forestay length. You can use whatever datum is most suitable for leveling the boat, but I would expect that if you trim the boat so the factory location of the boot stripe is level with the water you’ll be pretty close.
Then adjust for the curvature of the earth, and the 500’ difference in sea level that occurs depending on where you are in the world. (Not).
Ballast in. Then use your plumbob (a string and weight) in a bucket of water and trigonometry, as I mentioned, to set your rake. More rake= more weather helm. I would think that 2% is good, 3% is lots.
Then adjust the top shrouds to remove the sag in, and set the tension of, the forestay. This will bend the mast forward in the middle, so you will want to then tension the lower shrouds to the amount of mast bend you choose. Of course, all this time keeping the mast vertical and straight as viewed from the stern. And maintaining the required slight “up from horizontal” attitude of the spreaders. Make changes with the same number of turns to the adjusters/turnbuckles on both sides to keep things in line bow-to-stern.
If you have a backstay, that is used to control the sag and tension in the forestay, instead of the top shrouds. Of course it will still have some effect on the mast rake.
The most accurate way to set the tension in a cable without using gauges is by measuring the elongation over a defined distance. The thickness of the cable then is not relevant, (1/8”, 5/32”) you just measure the amount of elastic elongation from the hand-tight condition.
For example, failure occurs at 1% elongation, meaning that a 2 meter long cable will fail when stretched 2cm, or 20 mm, when its ultimate tensile strength is reached.
Measure a practical length of the shroud, say, 2 meters, but the longer the better. With the shroud hand tight only, measure from the swaged ferrule to a point on the cable 2m up and tape that point exactly. Using Catigale’s 20% figure, which sounds about right for aft-swept spreaders, you would therefore tension the cable until the distance between the two points is 2m and 4mm. (That added 4mm is 20% of the 20mm ultimate strength).
Pre-tensioning the top shrouds is critical to reducing sideways movement of the mast. The distance the masthead moves laterally is reduced by half, over if there was undertensioning.
The primary risk of too little tension, in addition to the mast movement I mentioned, is shock loading. That will do the shroud, and associated mechanicals in long before fatigue does, I would expect.
Under moderate sailing conditions you should see no curve in the leeward shrouds.
- Brian.
