Page 2 of 2
Re: Made a big gouge in the gel coat
Posted: Tue Nov 08, 2011 7:16 pm
Catigale wrote:Worst DOH!! I ever saw on a sailboat was a guy who neatly arranged his lines-led-aft blocks in a line on the mast - and drilled mounting holes all on one plane, then watched in horror as his mast neatly folded up and fell as the holes had essentially cut his mast 3/4 the way through....
Ouch!!!!
Posted: Wed Nov 09, 2011 4:33 am
Posted: Wed Nov 09, 2011 8:25 am
by Divecoz
Was That a Gate Latch? or a Lock Hasp?? Hahahahahah
Posted: Wed Nov 09, 2011 9:29 am
by raycarlson
catigale you sooo funny grasshopper!!!!!!
Posted: Wed Nov 09, 2011 9:57 am
by mrbillfll
Phil M wrote:mrbillfll wrote:
have you seen the pvc tubes on the bow to hold an anchor? (I have 2).
Have you posted this mod? I was looking for it. I wanted to see how the PVC tubes were attached.
Phil M
just some big hose clamps. (the larger anchor got high quality german hose clamps ($8/each IIRC), the other uses ones from HomeDepot... I'd recommend HD and replace them when they start to rust.
cutting them is the trick. (this is on a classic 26) I could have left them longer but then its a longer reach to put them in..
other angles:
http://i64.photobucket.com/albums/h169/ ... 010240.jpg
one tube:
http://i64.photobucket.com/albums/h169/ ... 010003.jpg
http://i64.photobucket.com/albums/h169/ ... 010022.jpg
