Re: Where to drill thru-hulls
Posted: Mon Feb 13, 2012 7:13 am
If Your Boat hangs out with lots of other boats in the water ( Marina... Mooring Fields etc..) and Unless the majority of those boats around you are Small Outboard driven runabouts?? Chances are ? The vast majority of the boats have 1 or more Below the water line Thru-hulls..
Can you use a hose tossed over the side for your wash down? Certainly you can, with the right pump.. What would you think if the dealer showed you that as a dealer or factory installed Option? But by all means it works.. Most A/C units Built In.. have one .. most inboards have at least one for cooling.. If you have a Pump over head ... you surely have that one beneath the water line.. My Experience has been? The Bigger The Boat ...the more of those you will find..
In 5 years of being in a Marina with over 1000 boats with thru-hulls ? I am unaware of any sinking because of thru-hulls.. Should you check them and inspect them once or twice a year? I do..I have seen a lot more issues with Oppss who forget to put the transom plug in!! Thank Goodness we dont have those.. Was I nervous with the first hole ? Yes I was.. It went fine, and remains to be fine , and then I cut another one... As for Now ? Both are fine..
I took my time, laying out where they would go.. Measure 10 times .....drill Once!!.. Prep properly.. Install using the proper sealant and devices.. I have the proper Bronze lockout for the head and Both have SS Ball Valves attached directly to the thru-hulls..
Its Not A Big Deal.. Its is or can be a Very Simple Procedure.. Its been done for a long long time, this is not something new..
Like so much else in life.. If your not comfortable with doing it , or having it? DONT!
