RobertB wrote:UPDATE: As a matter of fact, a quick internet search found at least one marine RF equipment manufacturer recommending Boeshield T-9 for protecting RF connections ( ThunderBird SSAS Ship Security Alert System product support manual
http://www.altronic.com/techdocs/Corros ... Manual.pdf).
After repairing your link, I checked it out. The manufacturer recommends the CorosionX product for use in resistive loads, sometimes called dummy loads. These devices, by definition, absorb the RF energy that is sent to them. I'm not sure that they have measured, or care about insertion loss due to the anti-corrosion product that they use, as this loss just prevents the signal from radiating. If someone will produce documentation (insertion loss chart, breakdown by frequency and power level, etc.) on alternative products, I would consider their use, but until then...
On the subject of dielectric greases containing metal, or graphite, I intentionally included "all" greases used for corrosion prevention, not just dielectric grease. Some anti corrosion greases designed for use in electrical applications do contain metals and are conductive. I just wanted the readers to be aware of this.
There are many products out there, but I choose to use one that is specifically designed to prevent corrosion and water ingress for RF connectors.
