tomchitecture wrote:I have a very "Stock" MacGregor 26s. 1991. I am the second owner. I have attachment points for a boom vang. I also am finding that I could be pointing about 5 degrees higher if I had a traveller. Anyone with experience on this boat: with and without vang or with and without traveller?
I am dialing in my sail trim and sheeting. My question is, are these controls worth the extra lines/bother/maintenance?
There have been a lot of suggestions here about rigging replacements for a vang and a traveller. What I'd like to emphasize is the reason most boats have a vang and a traveller. The two controls are used in concert to controll the tension on the leech of the mailsail, which in turn controls the twist. The mainsheet is, of course, the most obvious way of controlling the angle of the boom off-centerline (but it has the unintended effect of also affecting vertical rise of the boom and twist).
I personally think a dedicated vang is an essential piece of equipment. It's the primary control of twist on all points of sail and it's an easy thing to rig on every boat.
If your boat doesn't have a traveller,or if there isn't room for one in the cockpit, there are lots of almost-as-good substitutes that folks have devised over the last hundred years or so. But, IMO, the traveller is the most versatile and effective. You can almost always figure out a way to add a traveller on the transom of a boat,( although it does interfere with swimming off the stern!
As long as you have a way to contol twist, you're going to sail better, IMO. I personally believe it's good to be able to have two separate controls for the following because they interact (combine as two separate vectors acting on the boom) . I haven't had any experience sailing with two mainsheets, but I've had a lot of experience sailing with vangs, with and without travelers.
Upwind in fully powered up winds:The two most important guides for trimming a mainsail upwind are to keep the boom near or on the center line of the boat, and the second batten down (on a four batten main) parallel to the boom. At this point, the leech telltale at back of the 2nd batten should flow. If it doesn’t, you should twist the sail off more by easing the sheet and pulling the traveler further to windward (or the equivalent adjustment).
Upwinds fine tips: A slightly tighter leech (less twist) allows the boat to point higher, but requires more careful steering or else you will stall the top of the mainsail and slow down and slide sideways n the water. If the 2nd batten telltale stalls before the lower ones, you need more twist.
Reaching Downwind in moderate winds: Off the wind, the best rule is to keep the top or second batten down (3 or 4 batten main, respectively) parallel to the boom. Since the boom is further out from the centerline, the downward pull of the standard mainsheet is less effective, so a traditional vang is useful.
Running Downwind: The standard mainsheet is eased to let the boom far out. The vang helps control oscillations when following waves roll the boat. It really keeps the boom from bouncing up and down and the sail slatting as the boat rolls.
In choppy water or gusts, upwind and reaching,
A little more twist is desirable to avoid stalling and to keep the boat heeled at a constant 15 or 20 degrees. A little more twist is good for accelerating. In really puffy winds, if I have to stay on a specific course, I prefer to let the traveler in and out aggressively to control heeling without drastically changing the shape of the wing (mainsail). If I'm free to change course slightly with each gust, I prefer to steer higher in the gusts and follow the apparent wind angle as it changes. Steering higher in the gusts gives the boat a "lift"
Weather helm
If the rudder starts to load up, and you are steering hard to keep the boat from rounding up, or heeling too much, ease the boom downwind to decrease the angle of attach and reduce power.
The mechanics of controlling twist in the mainsail: You have to control two things separately: how high the boom-end can rise in the vertical plane, and how far off center-line the boom can move in the horizontal plane.
1) vertical boom control: how high the boom can rise, which controls the tension on the leech and the twist in the sail.
Vertical boom control is the traditional role of the vang (corrected on edit). it maintains constant vertical angle of the boom.
2) horizontal boom control: how far off center the boom can go. This is the traditional role of the traveler, when used with a vang which constrains the booms ability to lift up.
Easing the traveller changes the angle of attack to the wind, with negligible effect on sail twist/leech tension/vertical boom position. (added on edit)
2.1) If you want more twist in the sail without moving the boom further outboard ,ease the vang a bit and pull the traveler to windward a bit. The boom will stay in the same horizontal angle, but the clew of the mainsail will rise, inducing more twist-off in the upper part of the sail
2.2) If you want to reduce twist in the mainsail, tighten the vang a bit to pull the clew down, and ease the mainsail a bit.
I'm writing this off the top of my head, so I apologize in advance for any errors, typos, etc. I'll try to fix them later, if I catch them. As always, I invite others to point out any errors or omissions I've made. I'm counting on y'all !
Fair winds,
Judy B
Sailmaker
