Technically, sure. Just drill a hole in the cell, fill it with methanol, and plug it.Ormonddude wrote:I wonder if you can "hack" the fuel cells, in other words refill them yourself with off the shelf methanol ? The entire cut the need to dock to recharge is sort of silly if its now search the world for a replacement canister.
The issue is both impurities and introduced dirt in the methanol. These fuel cell generators work by passing methane through a platinum/palladium catalyzing grill that is exceptionally fine. These are laser-cut, nano-scale holes. This grill strips the hydrogen off the methane, reducing it to water and CO2.
As you can imagine, because the grill is made of two of the rarest commodity metals, it's very expensive to replace. Every particle in solution that isn't methanol can potentially permanently block these grill holes. The life of the unit is defined by the life of this grill, which is why they won't warranty damage caused by dirty fuel.
The problem is so severe that a about a gram of disolved salt will destroy a small grill.
It's this exotic grill constraint that makes the whole fuel cell proposition enormously expensive. Fuel cells really only make sense with natural gas fuels that by their nature won't contain particulate impurities that damage the catalyzing grill.
The process MAC explained is electrolysis--the separation of water into oxygen and hydrogen by means of a direct electrical current. It's similar but not the same as a catalytic fuel cell reaction. It's not used for power generation because it takes more power to separate the water into its constituent elements than burning them back together provides. It is used as a means to generate hydrogen in the laboratory when necessary because it's easy, but it will never be a source of power generation. Hydrocarbons contain far more hydrogen, so catalyzing them crosses the thermodynamic threshold and they become valuable fuels.
Hydrogen peroxide (H2O2), a close chemical relative of water, is so reactive (because of the extra oxygen) that it will combust violently in the presence of a number of catalyzing metals including platinum and even silver. But peroxide is expensive stuff because it has to be chemically produced and doesn't occur naturally (because it's so reactive that any formed naturally has already reacted with something).
It's always going to be hard to find sources of power cheaper than fuels that seep out of the ground ready to burn. Since cost is a function of difficult, there will never, ever be a cheaper fuel source than natural gas except sunlight, which falls upon us for free in even greater abundance. Fuels that are better in other ways, sure. Cheaper? No.
Matt
