First day on the Mac
Re: First day on the Mac
Dimitri-2000X-Tampa wrote:I don't know about a Mac 25 but I do know that my Mac 26X will not hardly tack if you don't have at least a piece of jib out to help push the boat around.
And even then, I find it works a lot better if I leave the jib sheet secured when tacking, and let the jib get backwinded to finish pushing it around, then cut the sheet loose and take up the downwind sheet. Took a while to figure that one out, as I'd find myself in irons frequently, no matter how fast I came about.
Too much freeboard, and not enough mass, I suppose.
SENCMac26x
Post by SENCMac26x »
No I had both sails up....but I seem to be disatsified with how it steers under most circumstances.
I'm begining to the think maybe the rudder is smaller than ideal?
These boats are 'under-ruddered' by most estimation.
Catigale wrote:These boats are 'under-ruddered' by most estimation.
I agree with this.
Also, rudders out of alignment and not parallel seems to be common. It's possible to adjust them on the X, not so much on the M.
SENCMac26x
RussMT wrote: I agree with this.
I can garauntee my rudders are NOT out of alignment! 8)
THE CUSCUS
Post by THE CUSCUS »
SENCMac25, can you post a picture of your rudder? When motoring, is your keel up or down? When sailing, how far down is it?
SENCMac25 wrote:I can garauntee my rudders are NOT out of alignment! 8)
:D I bet you are right.
