Page 2 of 2
Re: First day on the Mac
Posted: Tue Apr 09, 2013 5:18 am
by Tomfoolery
Dimitri-2000X-Tampa wrote:I don't know about a Mac 25 but I do know that my Mac 26X will not hardly tack if you don't have at least a piece of jib out to help push the boat around.
And even then, I find it works a lot better if I leave the jib sheet secured when tacking, and let the jib get backwinded to finish pushing it around, then cut the sheet loose and take up the downwind sheet. Took a while to figure that one out, as I'd find myself in irons frequently, no matter how fast I came about.
Too much freeboard, and not enough mass, I suppose.
Posted: Thu Apr 11, 2013 5:56 am
by SENCMac26x
No I had both sails up....but I seem to be disatsified with how it steers under most circumstances.
I'm begining to the think maybe the rudder is smaller than ideal?
Posted: Thu Apr 11, 2013 10:10 am
These boats are 'under-ruddered' by most estimation.
Posted: Thu Apr 11, 2013 10:32 am
Catigale wrote:These boats are 'under-ruddered' by most estimation.
I agree with this.
Also, rudders out of alignment and not parallel seems to be common. It's possible to adjust them on the X, not so much on the M.
Posted: Thu Apr 11, 2013 12:34 pm
by SENCMac26x
RussMT wrote: I agree with this.
I can garauntee my rudders are NOT out of alignment! 8)
Posted: Thu Apr 11, 2013 12:59 pm
by THE CUSCUS
SENCMac25, can you post a picture of your rudder? When motoring, is your keel up or down? When sailing, how far down is it?
Posted: Thu Apr 11, 2013 1:12 pm
SENCMac25 wrote:I can garauntee my rudders are NOT out of alignment! 8)
:D I bet you are right.
