davesisk wrote:Did a few hours of sailing on the Cape Fear river today! The wind was blowing around 15-20 knots I believe, with some occasional gusts of more. I probably averaged about 4 knots up the river (presumably against the current), and hit 7.5 knots a few times on the way back (presumably with the current).
Now, maybe something on mine isn't quite "tuned" right (or maybe it's the operator!
) but sure seems like the 26X has a LOT of weather helm (ie. when the wind blows hard and the boat heels hard, it automagically points itself into the wind). A small daysailor passed me easily because I kept turning into the wind unintentionally. Now, this is not necessarily bad I think...for instance, in an accidental overboard at least the boat would point itself into the wind and stall. So, I think a little bit weather helm is probably good. Maybe it was designed to do this to keep us from getting too stupid?
The "weather helm" response seems to happen very quickly though...the boat heels hard, and next thing you know it has pointed itself into the wind. Steering against it to correct doesn't seem to have any effect either. It seems it happens a little too fast for comfort though...I could see accidentally hitting something that you didn't intend!
Is this just me, or do other folks get the same behavior?
What you describe is called rounding up. The immediate and proximal cause is excessive heeling. It's tempting to fiddle with the rake of the mast or the tune of the shrouds, but what you really need to do is learn how to balance your fore and aft sail trim or depower your sailplan. Sail Power controls heel, and heeling causes the boat to round up unexpectedly.
You positively, abosolutel CAN'T round up unless you are heeling too much. Excessive heeling is the ONE thing that will round up every boat. From that we can conclude that the first thing to do is control heel by controlling sail power. Conversely: Excessive heeling will always cause you to round up even when the mast is raked the proper amount,
Too much heel is almost always caused by being overpowered. (Less frequently, heeling is is caused by crappy old sails behaving badly in aearodynamic rude ways) . So first, learn how to depower your sails.
#1 Learn to reef the main and foresail. That's the any-body-can-do-it way to reduce power.
#2 Concurrently, work on your sail trim and shape to reduce power. learn to use the traveller and outhaul together (to increase the angle of attack whilst simultaneously controlling twist) and using the outhaul (and mastben) to reduce the power of the mainsail. Make sure your forestay isn't sagging because that will increase the draft in your jib, which in turn increases power.
#3. If #1 and #2 are impossible to achieve, you probably need new sails.
#4. After getting #1-#3 right, adjust the mast rake for fine tuning. Mast rake affects the forward and aft position of the COE, and therefore acts as partial compensation to the horizontal component created when heeled. The horizontal component is the primary one. (unless the sails are as soft as bedsheets with no shape stability)
Here's some simplified physics, to set the record straight. A yacht is not a weather vane, with the bow pointing to windward.... rounding up is caused by too much heeling. I refer you to CJ Marchaj, Sail Performance, 2003, page 269 " The center of effort and its relation to the directional balance of a yacht" for a more rigorous discussion. (in other works, gimme a break
as you read this. I am avoiding using precise technical terms to dumb it down
enough that non-mathematicials and non-physicists can understand it)
1. Effect of heeling on directional stability.
1a) Well tuned yachts have "lee helm" if they are sail upright. They will turn downwind. This is normal.
1b1) this happens because the sailplan's COE (center of effort) is in front of the hull's CLR (center of lateral resistance = pivot point)
1b) Well tuned yachts heeling 15-20 degrees tend to have very slight weatherhelm. they will sail a straight course, with the rudder turned 2-4 degree off center line, with minimal pressure on the helm. (the shape of the rudder determines the amount of pressure caused by being a few degrees off, not the degree of deflections)
1c) Well-tune Yachts heeled 20+ degrees will tend to turn the bow into the wind, and require constantly correcting the course with the rudder. The more the boat heels, the greater the skipper will have to turn the rudder. At a certain degree off centerline, the rudder will stall out, and the boat will round up suddenly and uncontrollably. .
2) Directional stability of a yacht when not heeling. The boat will tend to turn downwind, exhibiting lee helm.
2a) When not heeling the COE of the sailplan is in front of the CLR by a little bit.
2a1) The Pivot point: The Hull rotates around an imaginary vertical line running passing through the front section of the keel. same as always.
2a2) The force: The wind provides the dynamic force.
when the boat heels, there's a horizontal couple formed by the center of lift of the sails vs the center of resisitance of the underwater hull & appendages.
3) Directional stability of a yacht when heeling. The boat is stable when heeled 15-20%, rounds up when heeled more than 15-20
3a) The tendency of the boat to change directions is caused by "moment arm" acting around a pivot point overwhelming other vectors. When the boat heels, the "imaginary" center of lift of the sails is outboard and to leeward of the pivot point of the hull, the bow of the boat will yaw into the wind.
3a1) The Pivot point: The Hull rotates around an imaginary vertical line running passing through the front section of the keel. We call that spot "imaginary" spot the center of lateral resistance. Think of the CLR as the pivot point for the hull. (it moves when the boat heels, but it's convenient to think of it as wandering around somewhere just a little aft of the leading edge of the keel)
3a2) The force: The wind provides the dynamic force. is generally designed to be located somewhere forward of the CLR. When the boat heels, this point moves outboard of the hull, to leeward.
4) The boat rounds up if it's heeling too much.
4a) If the boat is heeled too much, the horizonatal moment arm is longer, and the torque is greater, causing a round up.
I'm out of time. don't have time to write a primer on sail trim. but that's really what's needed next, now that we've cleared up the confusion about the physics of directional stability of yachts. Brian (Seahorse) has written some good stuff on trim, so read it.
Fair winds,
Judy B
Salmaker
