Page 2 of 3
Re: heeling and height-challenged crew
Posted: Sat Jun 07, 2014 7:28 am
Anything that's makes the admiral more comfortable will be worth doing.
I think the fear of healing is genetic. My admiral is tall and nothing seems to overcome that innate fear. For her it comes from the small size of our boats as she didn't feel this strongly on our 34' boat.
Posted: Sat Jun 07, 2014 11:39 am
by Phil M
RussMT wrote:Anything that's makes the admiral more comfortable will be worth doing.
Checkmark.
RussMT wrote: I think the fear of healing is genetic.
Double check marks. :D But remember, as a general rule women live longer too. Something about putting yourself in risky situations. Their survival instincts kick into overdrive. Ours gets overruled by testosterone. :P
Posted: Mon Jun 09, 2014 2:48 am
The X chromosome does seem effective in canceling ideas like..
"If we put a sheet of 4x8 on the forklift we we can take a cool group picture up in the air"
Posted: Mon Jun 09, 2014 4:35 am
by tlgibson97
Forgive my crude paint drawing.
Going with a new fllor idea, this is an idea I came up with that might be a solution. Basically, it's a double floor that is hinged on each edge that will flip up to connect in the center. It would be near 45 degree foot brace. It could be split into sections so that the whole floor isn't flipped up. Then it can be stowed flat when not sailing and you wouldn't need to take up any other space storing a board. It's just a thought.
edit: After looking at the drawing again, it looks like you might be able to stow it flat against the benches if you didnt want to have it as a floor. If you went that route then you could tailor the angle of the footrest based on the width of the boards.
Posted: Mon Jun 09, 2014 6:09 am
by Highlander
#1 Go to shoe shop
#2 Buy one pair of them clogs with 4" - 5" thick soles on them whoola !!
#3 If she should go MOB just look for said clogs floating up-side down in the water get them in bright red or yellow easier to see in the water than the pink ones :)
#4 2" strap along the center of the cockpit from pedestal to cabin hatch entrance same height off floor as cockpit seats now when heeled just put feet up on strap don't know if ped is strong enough to support that kinda weight say two adults but should be ok for younger kids
#5 buy a stretch rack for the Admiral then U can look up to the Boss !! :D :D :D :D
Posted: Mon Jun 09, 2014 8:17 am
by DaveC426913
tlgibson97 wrote:
Hah. She's not that height-challenged!
Shrink that to about 4" on a side, and I think that's what I'll do.
Posted: Mon Jun 09, 2014 4:45 pm
by Crikey
I like highlanders suggestion best. Like many competition boats (where heeling is excessively encountered), a strap suffices very well for foot under, as well as step-on, while retaining the companionway passage without any reduction in the traversing area. To divide that in half with a weighty device that must be manhandled back into place when powering seems counterproductive.
I'll admit, the admiral is never totally comfortable unless she's behind the wheel...
Posted: Mon Jun 09, 2014 10:05 pm
by Boblee
jimbo wrote:chuckle . . ah the old tip the porta potty trick - the ultimate angle of heel test. I do have a reputation for that both in the :macm: and dad's old yacht. But now the sucker is lashed down. It 'aint go'in nowhere now - well short of a complete capsize of course.
The test for the missus on our boat is when stuff slides off the table she starts going white and if theres any posibility of a sail going up you can bet the table is stacked with as much and many breakables as possible, crikey thats only 15 deg.
Posted: Tue Jun 10, 2014 6:59 am
by DaveC426913
Crikey wrote:I like highlanders suggestion best. Like many competition boats (where heeling is excessively encountered), a strap suffices very well for foot under, as well as step-on, while retaining the companionway passage without any reduction in the traversing area. To divide that in half with a weighty device that must be manhandled back into place when powering seems counterproductive.
If she is unhappy whenever the boat goes past 12 degrees, no mere strap under her feet is going to make her feel more stable.
No, I think the board is definitely the way to go for my purposes. All I have to do now is figure out how to attach it. I'm looking for some stainless steel slots that will grab pins projecting from the end of the board.
Hm. Maybe I'll employ pintles and gudgeons, if I can get them small enough and cheap enough.
Posted: Tue Jun 10, 2014 7:26 am
by RobertB
Solution is very simple, let her drive. :wink: :wink: :wink:
by RobertB
Posted: Tue Jun 10, 2014 12:13 pm
by DaveC426913
RobertB wrote:Solution is very simple, let her drive. :wink: :wink: :wink:
Yeah, that's my go-to, but she gets spooked easily, and then wants me to take over.
And she has the same problem at the helm. I can't seem to convince her how simple it is to merely sit on the high side. So if another footboard behind the helm makes her feel better, I'm all for it.
Posted: Tue Jun 10, 2014 9:09 pm
by Highlander
I'm thinking it might be cheaper & easier to get a new taller Admiral with sailing experience & $$$ :)
But then again I'm single ! :P Just Saying
I can just hear the Thunder Rolling In all these Admirals looking for a hangmans rope !!
Posted: Tue Jun 10, 2014 9:58 pm
by mastreb
I'm very fortunate in that my admiral loves sailing and extreme heeling. Not so much the big waves though.
Posted: Tue Jun 10, 2014 10:51 pm
by Johnacuda
Highlander wrote:I'm thinking it might be cheaper & easier to get a new taller Admiral with sailing experience & $$$ :)
Fortunately no one has modified a Mac to the point where it carried a yardarm, (yet). Otherwise, you might have endd up swinging from it! :?
