Page 2 of 3
Re: Replacement Sails
Posted: Thu Aug 20, 2015 6:31 am
by vkmaynard
Judy B wrote:...Please forgive my blatant self-promotion, but I think Hyde Sails Direct comes out on the top of the list when doing an apples-to-apples comparison...
Judy
Actually thanks for the facts!
We intend to by our sails from you. Looking forward to a custom 120-135 Jib with luff pad and two sheets so we can run both sets of tracks (even if we have to add an additional forward track) at the same time and compromise on pointing and reaching, The 150 is awful for pointing and the 100% jib is too small for reaching. Furling the 150 to clear the stays creates a useless diaper. We would also like to add sail area to the lower part of the main.
Victor
Posted: Fri Aug 21, 2015 7:53 pm
by Wet_Feet
Victor
Hey Victor, it sounds like you've done your research but thought I would pass along a note a saw on the BWY website....
"130% or 135% Genoas simply do not work well on any of these boats because the mast shrouds are attached all the way out at the hull. The wide shroud base makes it impossible to properly sheet these in between sized sails for proper upwind sailing. On all Macgregor and Venture models (as well as a lot of other boats) these sails really don't do anything well. They must be sheeted outside the mast shrouds so they aren't easy to tack, but unlike the 150% Genoa, these sails do not extend far enough past the shrouds to wrap around them, so they are VERY limited in their ability to sail close to the wind. With a 150% Genoa, the shrouds fall into the "pocket" of the sail so you can pull the sail in much closer. While you will get a little more power reaching and downwind than a 100% Jib, it's not enough to make up for the disadvantages."
Perhaps you've got something figured out? I'm pretty new to this sailing Gig but I'm assuming that when you reef a 150 Genny you have to relocate the sheets to the forward sheet rail (same place as they would be for a jib), and this is where you are getting the "Wet Diaper" Sail?
dthiesmeyer wrote:I just bought my new 26M RF Genoa from Judy. The few extra bucks is well worth the investment. I ordered my new sail and received it in less than four weeks. I am so impressed with the looks, quality and increased performance, I will get all my future sails from Judy!!!
What sort of a sail are you coming from?
Judy
Hi Judy, I'm sure your sails are very good quality and your comparison of the 6oz Dacron Main sail shows the value. I notice the BWY site advises that most coastal or inland sailors find the 6 oz sails a lot to handle. They also advise on their website they have found "5 or 5.5 oz with most mainsails, 5 oz for genoas and most Jibs being 5.5 oz give the best balance of performance, durability and ease of handling for each sail type. All of these sails will seem a little stiffer than the factory sails, but not to the point of being unpleasant to handle."
In regards to my specific situation, I am looking for an economical replacement for my furling Jib sail. I will be lucky to get 20 days a year out on the water, mostly in the summer when there is frequently just a breeze. I think the heavy duty 6 oz sail cloth may not be value added. Additionally I am considering moving up to a genoa at some point in the future (although Victors comments make me question that plan), in which case the Jib will just be stored away.
So to compare jib sails based on what I have learned....
(and adding consideration for our currently crappy CDN $)
BWY / Doyle - Made in USA (Seattle)
Furling Jib 5 oz Challenge High Modulus Dacron - $350 / CDN$455
or Furling Jib 5.5 oz Challenge High Modulus Dacron with UV cover - $495 / CDN$643
or Furling Jib 5 layer laminate performance sail = 7.4 oz Dacron - $950 / CDN$1235
VS
Judy B / Hyde Direct - Made in Phillipines
Furling Jib 6 oz Challenge High Modulus Dacron - $674 / CDN$876
or Furling Jib 6 oz Challenge High Modulus Dacron - $775 / CDN$1007
I'm guessing free shipping only applies to your US customers as your website quotes $102 / CDN$133 to ship to me in Canada. Too bad you can't just drop ship direct from the Phillipines for "free". I'm guessing BWY shipping is similar. I included the manufacture location as even if quality is equal or better, it is still important to many people.
The short story is I haven't been able to justify the spend for the heavier sail cloth...all else being equal. Thanks for your input though as I have learned more about sail construction as a result. I may regret my decision in a few years....or I may not, only one way to find out.
John
Posted: Fri Aug 21, 2015 10:36 pm
by vkmaynard
We'll see what Judy comes up with on a design for a larger jib. Will possibly require an additional set of tracks on the cabin top.
Always like to try something new. If it fails the back to a new 150.
The stiffer sail will have much better sail shape and performance.
Victor
Posted: Fri Aug 21, 2015 10:50 pm
by Judy B
vkmaynard wrote:We'll see what Judy comes up with on a design for a larger jib. Will possibly require an additional set of tracks on the cabin top.
Victor
Victor's right. The main obstacle to building a headsail between 100 and 150% for the X is that there genoa tracks are in the wrong place. The deck layouts of the 26X and M were optimized to make the interior of the boat huge, and as a result, the decks have very limited options to install additional tracks. But if anybody can do it, I'm sure Victor can. He's very clever and very technically gifted, as we all know.
He and I have discussed the potential for a jib between 125 and 140 if he installs tracks on the side of the boat, from the chain plates aft to the coaming. It's a bit unusual to install tracks on a vertical surface, but I've seen it done before.
Posted: Sat Aug 22, 2015 1:06 am
by Judy B
Victor
Judy
VS
John
WOW. There's so many things i could comment on here. I hardly know where to start. Sailcloth is a big topic, and a highly technical one.
Everybody knows that I've got an economic self interest here, but I'll try to suppply you with useful info, to teach you about cloth a bit, and then let you decide which sail suits your needs and budget best.
Everybody on this forum who has a 6 oz sail from me loves it. Not a single complaint :)
That statement "most sailors have a hard time handling 6 oz cloth" isn't true.
It is a publicly-known fact that Challenge Sailcloth doesn't make a High Modulus cloth in the 5 to 5.5 oz weight range. They publish their catalog online.
That means it's not possible for Doyle to build sails for BWY out of 5 oz or 5.5 oz Challenge High Modulus cloth.
BWY is highly respected for their honesty and good customer service. I sincerely believe they would never,ever intentionally or knowingly misrepresent their product. I really, really think there's been a verbal miscommunication between you and BWY.
Their website says 5.0 oz dacron and 5.5 oz dacron.
Their website doesn't mention "High Modulus" anywhere.
In fact, their website doesn't even mention Challenge anywhere.
Below is EXACTLY what It says, cut and pasted verbatim. This doesn't agree with the information in your last post.
JIBS, 100%
Standard Replacement Sails: (in stock, BWY Exclusive)
Roller Furling / 5.0 Dacron / NO UV cover $350.00 *
Coastal Cruising / Performance Sails: (in stock, BWY Exclusive)
Hank-on / 5.5 Dacron $395.00 *
Roller Furling / 5.5 Dacron / White UV Cover $495.00 *
Custom Sails: (made to order, appx. 4 weeks, BWY Exclusive)
Hank-on / Dacron Cruise Laminate / Tri Radial Cut $995.00
Roller Furling / Dacron Cruise Laminate / Tri Radial Cut / UV Optional $950.00
Because these sails are made to order, many options are available, call for specific prices
THERE IS NO SUCH THING AS 5 OZ OR 5.5 OZ CHALLENGE HIGH MODULUS CLOTH.
Challenge 5.53 has 250 x 300 dernier threads in the weave. It does not weigh 5.53 oz
Challenge 6.03 has 250 x 400 dernier threads in the weave. It does not weigh 6.03 oz
They both weigh exactly the same. 6 oz.
The difference in thread diameter are offset by threads per inch and density of weave, to arrive at the final weight.
Challenge has another product line called "Performance Cruise", but none of those weigh 5 oz. They are softer than Challenge High Modulus Dacron. They are stretchier too. The cloth is a less expensive, budget grade of cloth. Good cloth, but definitely stretchier than Challenge High Modulus.
All the product codes end in x.18.
Challenge 4.18 has 150 x 250 dernier threads, It weighs 4.3 oz
Challenge 5.18 has 150 x 250 dernier threads. It weighs 4.6 oz
Challenge 6.18 has 150 x 450 dernier threads. it weighs 5.6 oz.
CHALLENGE PERFORMANCE CRUISE DACRON IS STRETCHIER THAN HIGH MODULUS, even when they are both of equal weight.
Here's an example:
Challenge Performance Cruise 6.18 is a lot heavier than Challenge High Modulus 4.93.
Despite the heavier weight, it significantly stretchier because.
Also, in the 4-6 oz range, it is pretty fragile because it has narrow 150 dernier threads that don't last long when exposed to UV or flogging.
I avoid selling cloth with 150 dernier threads whenever possible because it doesn't last as long as cloth made of bigger threads.
As a final bit of advice to everybody, I will repeat something I've said many times:
I recommend you buy the best sails they can afford, unless you plan to sell the boat in a year or two at most. By "best sails", I mean the ones that will hold their shape the longest. Over the medium to long term, sails that are less stretchy save you money because they make you boat perform like new. Sails that hold their shape make sailing safer and more fun. You point higher, heel less and it's easier to control the boat.
IMO, it is no fun AT ALL to sail with stretchy sails. Boats with stretchy sails handle like crap and are hard to control
In order to comparison shop, you have to compare the style of the cloth, not the weight. Weight doesn't tell you how stretchy the cloth is.
Judy
Posted: Sat Aug 22, 2015 6:37 am
by vkmaynard
Great advice Judy!
Is there anyway to add additional sail area to the main closer to the foot?
Victor
Posted: Sat Aug 22, 2015 6:42 am
by grady
Wet_Feet wrote: BWY / Doyle - Made in USA (Seattle)
VS
John
You are hung up on "made by Doyle" Yes those sails are "made by Doyle" However they are not what I would consider high quality sails! They are good sails and are fine for any sailer that does not care about performance or longevity. There is no way BWY is Challenge sail cloth, I will have to aggree with Judy on that one. I have had 4 sails made by Doyle However they were custom made to fit the boat for performance. My main is Challenge sail cloth. The price over double of a stock sail. However it fits perfect. I had to provide mesurements of everything including pictures of mast bend at 50% and 100% so it would fit. When they made my spin they put all the mesurements in and the computer spit out a sail. However the designer did not like the look so he changed it and made it wider. With stock sails you are not going to have a professional sail maker making sure it is right.
Posted: Sat Aug 22, 2015 10:51 pm
by Judy B
vkmaynard wrote:Great advice Judy!
Victor
Hi Victor,
I can build any sail you tell me to build, but to what purpose? Give me a "design brief" and then let's address that.
For example, one way to increase power is increase the roach area. But you'd need to modify the backstay to avoid getting the roach caught on the back stay in very light air. Have you considered installing a backstay flicker or re-engineering the masthead crane ?
Increasing the roach will add sailpower, of course. will affect how much the boat heels in a given breeze. You've changed the ratio of sail area to righting moment, You would probably need to reduce sail area at lower wind speeds than before.
Adding sail area at the back will also have an affect on the balance of the helm, (probably not too huge, but that's a WAG, not based on analysis). You may need to alter the mast rake to reduce weather helm, or change the angle of the daggar board when beating to windward.
More importantly, I think you the boat will get more tender with increased drive. The righting moment of the boat will remain constant, but the drive will increase. You don't have to worry about the magnitude of the loads increasing, but you do have to consider how the change in rig geometry alters the distribution of the loads.
Best,
Judy
PS to all
I frequently get asked to advise people how to modify their rigs, sailplans, rudders, boats etc. Unfortunately I have to say no to such requests. I can't get involved in boat modificaton projects in the capacity of a technical advisor. ..... it's fun as a creative hobby, but it doesn't pay the bills, it takes me away from paying customers and it exposes me to legal liability.
In Victor's case, however, he is quite capable of doing all the engineering himself. Victor is technically gifted and fun to talk to. I am quite happy to build sails to fit the modifications he makes to his boat.
Posted: Sat Aug 22, 2015 10:57 pm
by korn_kid_12
I went with Peak sails and got 6.0 dacron, Cunningham, 2 reefing points, on main and 150% furling genny for a headsail with sacrificial sail material sewn in. for $1200 around Christmas 2013. If you want to talk about new life in the boat these did it!
Posted: Sun Aug 23, 2015 8:12 am
by bwytodd
Hi, this is Todd from Blue Water Yachts. I just wanted to give an update on our current sail offerings. Any of you who purchased sails from us in the last few years got either Doyle Offshore sails (made in Barbados) if you bought the basic factory type sails or Rolly Tasker sails for most of the upgraded but not super high end sails. Our Custom sails have been made in Seattle for some time now. NEW FOR 2015 we have upgraded nearly all of our more popular sails to BWY exclusive designs made here in Seattle by our local Doyle loft, we have made a lot of upgrades over the old factory style sails. Improvements include, upgrade from 3.9 OZ cloth to 5.0 or 5.5 OZ (depending on application) Challenge High Modulus Dacron, flatter cut to reduce heeling and improve pointing ability upwind, better hardware, loose footed design on mainsails and the availability of very attractively priced headsails that include UV covers.
These sails offer every bit of the quality and durability you would get from the higher priced suppliers, but are optimized to get the best performance from your Mac. The staff at BWY has nearly 100 years of combined experience selling, owning, cruising and racing Macgregor boats, we are the Mac experts! Because we sell more Mac parts and equipment that anyone else, our new sails are produced in large batches so we are able to give you the best quality available at very attractive prices.
If you are looking for the absolute best, check out our custom sails. These sails are made using Dacron Cruise Laminate cloth, essentially a racing Mylar cloth with very light layers of Dacron Laminated to the outsides to give great durability and ease of handling. All of these sails use Tri-Radial designs for great performance and a really racy look. In most cases these sails are not a lot more expensive than most sailmakers premium Dacron sails, but are in another league of performance and Life. While similar to Dacron sails in ultimate life, laminate sails have the advantage of staying very close to optimum shape right up to the end, while even the best Dacron sails gradually get stretchier over time.
I hope this clears up some confusion, if you have any specific questions feel free to email me. [email protected]
Posted: Sun Aug 23, 2015 8:20 am
by bwytodd
Sorry, I should add for clarity, what we refer to as HIgh Modulus 5 and 5.5 OZ are really 4.93 and 5.53, I guess rounding for simplicity actually caused more confusion than it eliminated! Also, many of you who have commented that Doyle sails that you have purchased from us over the years do not appear to use this high quality cloth are correct, the older sails were the straight factory sails, the new sails are totally different and greatly improved.
Posted: Sun Aug 23, 2015 3:19 pm
by Neo
For someone that knows absolutely nothing about sails I have to tell all you guys that this thread is GOLD!!!
Thanks.
Neo
Posted: Mon Aug 24, 2015 5:06 am
by dlandersson
So...used bedsheets are a no-go? :cry:
Neo wrote:For someone that knows absolutely nothing about sails I have to tell all you guys that this thread is GOLD!!!
Thanks.
Neo
Posted: Mon Aug 24, 2015 5:25 am
by Neo
dlandersson wrote:So...used bedsheets are a no-go? :cry:
Nope....only fresh bedsheets will do :D
Posted: Mon Aug 24, 2015 6:19 am
by dthiesmeyer
Sorry for the delay. Have been 'off the grid' for the past few days.
I went from the standard hanked on jib to a Hyde 150% Genoa on a CDI Roller Furler. The performance increase was 1-2 mph in moderate to heavy winds.
