Re: Forestay wire and furling advice needed
Posted: Fri Jul 08, 2016 10:19 am
Thanks, that makes sense.Wind Chime wrote:Similar to a "tack line". Sometimes referred to as a "tack pennant". http://www.holiday23.co.za/Fine%20tunin ... Furler.htmromandesign wrote:Can you please elaborate on the pony line? I'm not sure I understand how it would work, the geometry is not clear to me.Wind Chime wrote:Romadesign; by the looks of your rig in the photo, you have 2 choices.
1) add a second tang above the forestay tang (such as many of us have done to accommodate a spinnaker halyard).
2) attach a short (12") pony line between your existing tang and the turning block. This might get the halyard far enough forward and away from the furling extrusion that it does not foul when rotating the headsail on the furler.
Darry
12 inch long metal wire (same size wire as the forestay) with loops on both ends. One loop goes around your mast tang (same place as your forestay roller furling is attached) the other end second loop goes around your turning block of your "spare" halyard.
This 12 inches gets it away from the top of the roller furling extrusion, so it won't foul when rotating the Furler.
could kill
