OverEasy wrote: ↑Sat Dec 04, 2021 9:49 pm
That flooring looks great!
How thick is it?
Is it solid wood or is there a backer material?
On to your companionway shower….
Is it draining into the main bilge and then pumped overboard?
Or is it collected into a grey water holding tank to be pumped out at a sanitary facility?
Let me take the questions in reverse order: "Draining into the main bilge" for the shower is not an option.
We have all seen this picture of the MAC M bilge but except for the very early models this picture is a lie:
The ACTUAL bilge at the rear of the MAC m looks more like this:
In the pictures above you will see a yellow circle where the shower sump is mounted, that's a lie too - my mistake - the sump is actually inboard of that ballast channel. The only place on the boat lower than this (that is not inside the water ballast tank) is under the batteries. That's no place to mount a shower sump - so this place under the dinette is about a low as you can really go.
Even the picture from the factory shows that the ballast tank is not what is drawn in the cross section:
The red circle shows the rear of the ballast tank and the yellow circle shows yet another change made to the later models: A large wide spline molded into the hull right about midships. This is where the boat rests on the factory trailer. This is where the battery is and
this is the lowest place on the boat. This is also where the dinette seat is as you can see in this factory photo:
(I circles the areas in red that fit together)
So, why am I boring everyone with all these details about our boats? Well, when you talk about shower sumps and bilge pumps it's really neccessary to know the construction of the boat under your feet. It's critical for getting things right.
So here is the location of the shower sump in 'boat':
Here is the sump:
And here is the pump:
When water goes into the sump, the pump sends the water to this thru hull above the motor well:
So, in answer to your question:
What happens is the water shoots out of that hole into the motor well:
And, as we all know, the motor well drains out to the ocean, but as your question eludes, what if your in Canada or California near a shore and the Communists are near and you don't want to get caught draining the shower?
You just take the little rubber plug that comes with the factory galley sink and you use it to plug up the motor well drain and all that shower water will just stay in the motor well until your ready to dump it. I figure the motor well holds about 5 gallons - that's enough for two people to take a shower.
