Page 2 of 2
Re: First post from a Newbie
Posted: Fri Sep 16, 2016 3:02 pm
by Bilgemaster
md80max wrote:The bottom of the boat already had bottom paint on it and was in good condition, not new but good condition. Thank you for the suggestion!
I am led to understand that sticking with the same brand and type of bottom paint for that last coat is usually a good idea, unless you want to sand her down and start from scratch. (Hint: You don't.) Accordingly, before too much time passes, you might do well to ask the previous owner to tell you exactly what's on there now. With a bit of luck they may even have a bit, or even a lot of it remaining in the can in their garage for a little touching up here and there at the end of the season.
As for really cleaning her up, top to bottom, which will REALLY make you feel great about her, if you do not already have a pressure washer, then I simply cannot recommend Harbor Freight's little cheapo electric one highly enough. It's just the right amount of cheap and crappy and weak, so you simply can't do any harm. Just don't tug it around by the hose, or the plastic filter/inlet hose thing might break. Swab her down with a cup of Wisk laundry detergent in a bucket of water, give her a good blasting, wax her down, and she'll look brand new. Those pressure washers frequently go on sale for less than 80 bucks American.
Posted: Fri Sep 16, 2016 6:46 pm
Check to make certain the lake you sail in does not have restrictions on certain types of bottom paint. For example, lake George, in the Adirondacks of New York, will not allow boats in “the lake painted with anti-fouling paint containing TBT, or Tributylin, it is not allowed in the lake, unless it was applied in New York State by a registered Commercial Pesticides Applicator”
Posted: Sat Sep 17, 2016 6:59 am
by Bilgemaster
NiceAft wrote:Check to make certain the lake you sail in does not have restrictions on certain types of bottom paint. For example, lake George, in the Adirondacks of New York, will not allow boats in “the lake painted with anti-fouling paint containing TBT, or Tributylin, it is not allowed in the lake, unless it was applied in New York State by a registered Commercial Pesticides Applicator”
Not to worry, TBT's have been banned in the USA since the late '80s except for special permit use on larger ships and in some outdrive spray coatings (later banned here in the '90s). So, unless you hauled you new 26M out of a time machine or it had its bottom done by a guy named Fong alongside an alarmingly green creek just outside Shenzhen, or maybe visited Trinidad lately, Lake George should welcome you and your bottom with open arms.
How a painted bottom welcome most anywhere might appear
Posted: Sun Sep 18, 2016 6:29 am
by dlandersson
Where can I get one of those? :)
Posted: Sun Sep 18, 2016 8:42 am
by Jimmyt
Not sure it would look as good on you...
Posted: Mon Sep 19, 2016 12:08 am
by Signaleer
If he is truly a newbie....Isn't it appropriate for Peaches to welcome him? 8) :D
Posted: Mon Sep 19, 2016 6:44 am
Signaleer wrote:If he is truly a newbie....Isn't it appropriate for Peaches to welcome him? 8) :D
Peaches is always welcome on this site, but I haven't seen 'the picture' in quite a while.
Posted: Mon Sep 19, 2016 10:00 am
by Wind Chime
Not sure how good this is - as it looks to me like the hull has a vertical stress crack?
Posted: Mon Sep 19, 2016 1:25 pm
by budgates
Not sure how good this is - as it looks to me like the hull has a vertical stress crack?[/quote]
I'm sure this particular stern is supposed to look like that. ;)
