Page 2 of 2
Re: Question on raising the gooseneck after mast replacement
Posted: Sat Jun 17, 2017 2:30 pm
by taylormade
133bhp wrote:Mast rake is a factor , mine was std 4d deg or more and would foul the bimini. I run it a degree or two off vertical with some prebend. Its pretty nuetral at the helm.
tip, do something about the mast wires, they clang internally, gets on your nerves,
Thanks! Yeah, I plan on wrapping wire ties around them and then leaving the "tag" on so that they stay off the sides.
Posted: Sat Jun 17, 2017 8:21 pm
by stuendan
Hi Taylormade,
Just moving on a bit, do you happen to know the size and preferred material for the rivets used to attach the gooseneck to the mast? Mine are a little loose and I'd like to replace them. The existing rivets look awfully like stainless but I struggle enough with Aluminium rivets. Is monel a good compromise?
Cheers, Stuart
Posted: Sun Jun 18, 2017 2:05 pm
by sailboatmike
Monel is far better than Aluminium or Stainless, Aluminium isnt strong enough and you will get electrolysis between the gooseneck and the rivets unless well insulated same issue with stainless steel rivets that are strong but will cause electrolysis in the Aluminium mast.
Monel is pretty strong and wont overly cause electrolysis issues.
In any case use a insulator ( Duralac) between the gooseneck and the mast and in the rivet holes
