Bow in Mast.
Re: Bow in Mast.
adudinsk wrote: Sat May 02, 2020 12:08 pm Nope. did not remove foam.
Changed the bearing.. looked up it.. no foam for a few feet (until darkness.. anyway).
The foam is only at the top of the mast. I think the top 3-4 feet.
adudinsk
Re: Bow in Mast.
Post by adudinsk »
Oh.. then I might still have all of it..
I only looked up from the bottom.. (boy.. that doesn't sound good.. :) )
AD
Re: Bow in Mast.
Bow in the mast is from being stored 1 season with no pin in the foot plate to keep the mast from rotating.
That allowed the mast to turn and subsequently bow without a support in the middle.
Added pin, kept mast from rotating while stored, no more sag in the middle.
Also, when you put the mast up, no bow.
The shrouds and forestay put everything exactly where is should be, no adjustment needed.
Re: Bow in Mast.
Hi beene! :P
Re: Bow in Mast.
BOAT wrote: Thu Jun 11, 2020 1:57 pmHi beene! :P
Hi Boat... Nice to see you're keeping your M nice and clean inside.
Looking good
adudinsk
Re: Bow in Mast.
Post by adudinsk »
I hoisted it , and a friend helped to tune rigging.. its fine.. most masts at the club are similar.
