Page 2 of 2
Re: Why is motorized steering so hard with rudders down
Posted: Fri Jan 07, 2022 9:05 am
by Starscream
Here is a video showing my solution to the problem of rudder kick-up during accidental grounding. Note the change to 3/8" rudder line to allow enough wraps around the cleat.
There were a lot of questions about this technique on a FB thread, so I just video'd it instead of trying to explain. It's worked in multiple grounding events, although it's still quite a severe impact.
<iframe src="https://onedrive.live.com/ ... ></iframe>
Posted: Fri Jan 07, 2022 10:39 am
by OverEasy
Hi Be Free!
That is so cool!
We didnβt even know such a thing existed!!!
That is SOOOOO much better than what weβve used!!!
We did the break away string as an impromptu fix with what we just happen to have aboard at that moment.
(And,
like a lot of things in life that are impromptu solutions of the moment
, sorta just kept being used
β¦ )
What youβve done is SO much more well thought out and practical!
No more teasing the Bull Sharks!
Do you recall where the cleats came from or what they are called?
Thank you!!!!
Best Regards
Over Easy
Posted: Fri Jan 07, 2022 12:11 pm
by Be Free
Posted: Fri Jan 07, 2022 12:43 pm
by OverEasy
Hi Be Free!
Thank you!
A pair will be on order as soon as we get back down South.
Again thank you!
Best Regards
Over Easy
Posted: Fri Jan 07, 2022 12:45 pm
by OverEasy
Hi StarScream!
The video link comes back as an error messageβ¦
Best Regards
Over Easy
Posted: Fri Jan 07, 2022 1:16 pm
by Be Free
OverEasy wrote: βFri Jan 07, 2022 12:43 pm
Hi Be Free!
Thank you!
Again thank you!
Best Regards
Over Easy
Look around. West Marine is seldom the least expensive option. They are great when you need it today though!
I don't know if you noticed but there were two fairleads on the transom to route each of the white ropes from the bottom of the rudder up toward the cleat. Altogether it's two cleats, four fairleads, large lifting line (easier on your hands), small downhaul line, and shock cord.
Posted: Fri Jan 07, 2022 1:34 pm
by OverEasy
Thanks
