Re: Water pump for sink. Advice?
Posted: Sat Jan 29, 2022 1:42 pm
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=28794
The other advantage is it uses significantly less water. The difference between having to do something to get water (pump) vs having to do something to stop the water (reach over to the lever) is huge.topcat0399 wrote: ↑Thu Jan 27, 2022 3:18 pm I use a Whale Foot Pump that draws water from tanks I have under the V-berth (4 5 gallon jugs).
Works nicely and doesn't use juice, which is important to me.
Of course I had to run hosing which was a pain...and I do have to switch jugs when one runs out.
Trade offs trade offs....
That is a great point Wyb2!Wyb2 wrote: ↑Sun Jan 30, 2022 8:06 amThe other advantage is it uses significantly less water. The difference between having to do something to get water (pump) vs having to do something to stop the water (reach over to the lever) is huge.
Whether or not that matters depends on your use case, but if you are ever trying to conserve water a 12v pump quickly goes from being a convenience to being an annoyance.
That pump will give you about 1 gal/min at 10 ft of head if my napkin scratch is correct. The curves and data don't mention NPSH, so I would probably vote for a submerged install to have the best chance of getting a reasonable flow out of the faucet. 10 ft isn't much to work with, so I'd want every bit of it available on the pressurized side of the pump.OverEasy wrote: ↑Sat Jan 29, 2022 6:00 pm ...the thought came to mind that a small quiet centripetal pump could also work with one of those electric switch faucets (that our Very NicePO gave to us)!
This pump gives the option of running it as a submerged pump and looks like it could fit in through the blue water cube opening. This would allow us to not make any holes in the tanks.
The alternative is to make the holes and seal them with watertight gasketed fittings to have the pump outside the tanks.
Any thoughts?
Best Regards
Over Easy![]()
OverEasy wrote: ↑Sun Jan 23, 2022 9:13 pm Here is a baseline of considerations and are a couple options…. For 12VDC powered pumps.
https://soundproofempire.com/quietest-rv-water-pump/
How about a virtually silent operating system?
This is Another option if you’re interested is making a simple pressurized water tank out of PVC pipe (4” or 6” diameter) end caps and related fittings such as tees, elbows, reducers, fill cap, barb fittings, a couple band clamps, tygon vinyl tubing and a threaded Schrader valve.
You fabricate it to fit your particular needs and available space.
You can also fabricate one out of black PVC pipe to mount to your mast as a portable solar hot water shower supply if desired.![]()
You only need a small amount of air pressure to lift water to the sink or even up on deck from the side or bottom bilge spaces if desired. About 5 to 15 psi of air pressure should be more than sufficient with a hand air pump (small bicycle type is more than sufficient) periodically.
You don’t need much.
You can lead the pressurization line to just about any convenient location as you may desire with a flex line.
No electrical power requirements!
No switch mounting or wire routing!
No pump noise at all!![]()
We’ve used similar systems in RVs since I was a kid!
Best Regards,
Over Easy![]()
