Page 2 of 2
Construction Material type and weights
Posted: Tue May 31, 2022 4:09 pm
by Sheppie62
So I am done for now with the countertop, will build drawers when I have time. The bamboo plywood I used was 60lbs for a 4 x 8 sheet (I used less than half the sheet) about 50% heavier than normal 1/2” plywood (40lbs). But I believe it to be at least twice as strong. I considered using 1/4” and doubling where needed. I also used 100 stainless steel threaded dowels in the construction (6/32 screws with heads cut off) in every epoxy glue connection. I also used a bit of 1/2” birch plywood for areas that wouldn’t be seen, it’s way cheaper and lighter too. But I think the 1/2” bamboo was perfect for the spans I needed. The sink was about 9 lbs and together the countertop was 43 lbs with the epoxy coating. Drawer weight ? 3 lbs each = 6lbs. And shelving below in birch plywood about another 20lbs. Metal post/ connection hardware about 3 lbs . So total weight about 72 lbs total ? Will I win races? No. But my wife loves to cook now with the improved kitchen so it’s a win for me. :D
Re: Securing Appliances to boat countertop etc.
Posted: Tue May 31, 2022 5:05 pm
by Stickinthemud57
Nicely done. Looks very professional. Where do you get bamboo plywood?
Posted: Tue May 31, 2022 5:17 pm
by Highlander
NiceAft wrote: Tue May 31, 2022 3:39 pm So John,
With all that you have shown, where do you keep your scotch :?: You must have made a cabinet for that :?: My preferences are Islay’s. The others are too tame.
Ah Ray
Really now that would b telling , Do U think I just got off the boat literally "new immigrant" :D :D :D , I,ve been hear for a while now , been around , not the gullible type ! :P
All kiddin aside :wink:
Only my daughters know my secret hideout statches :)
but u can keep on being inquisitive :D :D :D :D
But U can always share U,r stash with me ! :D
Posted: Tue May 31, 2022 5:31 pm
by Highlander
Sheppie,
Holly Molly , u running a full fledged restaurant from that galley :) think u need a dishwasher tho cause who ever is doing ur dishes left the sink full of dirty dishes or did u get fired ! :P
nice mods always nice to see other peoples idea,s to suite their priorities ! :)
Posted: Tue May 31, 2022 6:01 pm
John, not a problem; come on down, I share🥃
Bamboo plywood
Posted: Tue May 31, 2022 7:49 pm
by Sheppie62
Stickinthemud57 wrote: Tue May 31, 2022 5:05 pm Nicely done. Looks very professional. Where do you get bamboo plywood?
I got it from a company called Cali Bamboo. It was crazy expensive, had to wait a month to get it, then had to have it shipped from the warehouse in Los Angeles. I’m not sure I would do that again. But I have to say it exceeded my expectations, great material to work with (just don’t slide you hand over a freshly cut edge, you’ll end up with a bunch of tiny needles broken off in your fingers!) sand slightly first. I have found a few pieces in stock at a few hardwood lumber yards, but they were all wrong thickness, wrong grain I wanted, wrong color (carbonized) etc. Birch plywood is reasonable, and available if you can make it look satisfactory with stain or ? I don’t know much about that. Bamboo sheet was $325 ? Plus shipping. Birch $50-60, find local HD, Lowes. But good thing is I have enough left over to build a table in the cockpit.
