Re: Fuel water separator recommendation
Posted: Fri May 03, 2024 7:23 pm
Hi All!
Glad (and a bit humbled) you found found our fuel system interesting!
Might I suggest that, even if you want to have removable fuel tanks to suit you circumstances, we would highly recommend setting up a fuel selector valve to change over from one tank to the other without having to disconnect/re-connect while out on the water. We’ve found it SO MUCH BETTER / SAFER / FASTER / EASIER than how we started out with Over Easy.
Having the boat side fuel filter/separator is much easier to check and drain than any engine mounted filter/separator and is something we’d highly recommend. Especially if you can’t get ethanol free fuel.
The prices for a fuel selector vary from supplier as you can see below:
These are three way selector valves, all are fuel rated, all are brass and all look the same.
Prices range from $47 down to $25
I’ve no doubt with a little more hunting one could probably find it for even less.
I recall we paid around $30 something back several years ago.
Again, Thank you!
Best Regards
Over Easy
Again, Thank you!
Best Regards
Over Easy
