Mac 26X with every Mod and upgrade listed with some pics
pitchpolehobie
Re: Mac 26X with every Mod and upgrade listed with some pics
Post by pitchpolehobie »
sounds like a great idea. im also interested in the western islands of georgian bay.
2002 MacGregor 26X: Remedium
Tohatsu 25HP
pitchpolehobie
closehaul wrote: Fri Nov 18, 2022 6:07 pm Pitchpolehobie and other Midwest MacgregorSailors, Let’s think about a North Channel Rendezvous in Summer 2023. Maybe the same week the TrailerSailors will be there (for those that will already be in the floatilla). Most of my mods are spin-offs from other Macgregor Sailors - seeing your boat would be inspiring. We all can learn from each other. Regards, Closehaul
Where are you based
Tohatsu 25HP
svscott
Sailboat: MacGregor 26D
Post by svscott »
Pitchpolehobie, that is quite the list of mods. We'll have to actually sail together next season! These things have a trailer for a reason. I'm planning on slipping the 26D next year and will bounce around from place to place on the X.
I'm for sure interested in a group trip in the Northeast next summer.
pitchpolehobie
svscott wrote: Sat Nov 19, 2022 3:16 pm Pitchpolehobie, that is quite the list of mods. We'll have to actually sail together next season! These things have a trailer for a reason. I'm planning on slipping the 26D next year and will bounce around from place to place on the X.
Agree - we need a better weather window. I'm looking forwards to doing some more 3-4 day/wkend Erie sails next season.
Tohatsu 25HP
closehaul
Post by closehaul »
pitchpolehobie wrote: Sat Nov 19, 2022 10:00 am
Where are you based
Pitchpolehobie, I am located near Moline, Illinois on the Mississippi River. Roughly 750mi to trailer to the North Channel Ontario (and I do it every year or so). I see you are located near Akron. One of my mods for distance trailering is to remove the spreaders and lower mast til horizontal with a short center support at the mast step. Also temporarily move the forestay to a U-bolt at top of mast which enables roller furling drum and foil to hang below the mast and not overhang the bow pulpit. Finally, spiral wrap everything (shrouds, stays, halyards, foil) to the mast with the topping lift or other line. Makes a 60MPH friendly rig. Regards, Closehaul
pitchpolehobie
closehaul wrote: Thu Nov 24, 2022 5:18 pm
Where are you based
Thats not too far from here. ID love to do a north Chan-Georgian bay cruise. Its about 5hours from here to put in at the south end. This year is a bit tricky as Im expecting my first child in January so its tough to commit to any summer dates. I sail with a Potter 19 crew and they're really interested in a Georgian bay trip too. We will likely do some Erie trips this year if I can sneak away for some long weekends. Have you done the western islands of Erie?
Tohatsu 25HP
pitchpolehobie
Just installed new USB DC power adapters w inline fuses and bus bars on my batteries. What are the fuse sizes in the original switch panel for the 26X? I think the PO left a few in a box but i dont recall them being labeled.
Tohatsu 25HP
Be Free
Post by Be Free »
All of mine were 5 amp. You need to look at the wire and size the fuse to match what's actually there though.
pitchpolehobie
What are the physical dimensions of the fuses? 30mm?
Tohatsu 25HP
Macsailing
Post by Macsailing »
Wow, those are some mods!
How do you like your solar vent on the front hatch?
Did you have to cut a hole?
Has anybody figured out how to vent the cabin, while boat is stored without cutting a hole in the hatch, or leaving the door open?
Scott
2010 26m, suzuki bf70a.
San Diego Bay
pitchpolehobie
Macsailing wrote: Wed Apr 19, 2023 7:48 am Wow, those are some mods!
Some took a bunch of energy but generally worth it. Most important would be steering mod and some done to make single handing easier on deck.
--its great id recommend having 1 on a 26x.
----prior owner installed an old solar fan; marinco brand; it ran 247365 so had burnt out. It was best to replace entirely. It was drop in and I used butyl tape to waterproof it. Works great definitely helps reduce any odor and dampness
Prior owner.
I use this in thr winter. I have a tarp over so the above solar fan doesnt work.
https://www.caframobrands.com/9406caabx.html
Scott
Tohatsu 25HP
pitchpolehobie
New Vinyl name printed from lettering.com the last one I had the red faded after 2 yrs. They were nice to send me 2 new ones for free. Supposed to last 5 to 7 yrs.
Tohatsu 25HP
pitchpolehobie
Head door was separating from wood underneat. Stainless bolts and nuts
Tohatsu 25HP
Hi PitchPolehobie!
Nice door storage for the bits and bobs!
Looks to keep them viewable, organized and handy.
That’s got to be one of the biggest organizational challenges…. Where/How to keep all the little things one needs with out having to rummage through an over stuffed bin of misc small stuff all competing to hide from ya when ya need it. :D
Best Regards
Over Easy 😎😎🐩🐈
I know that feeling.
What I did was to place semiopaque plastic bins with latch close lids in all of the bilge compartments under the seating areas. I lettered them A, B, C, etc. I then listed on a legal pad what was in each lettered bin, and where it is located; i.e. Port Starboard dinette seat, etc. Now, when I need to locate something, I look at the list and go to that bin. I don’t worry if what I need is in there. I trust the list. I should point out that I also laminated the legal pad list. It’s a boat. Things get wet. :D
At the moment I am on a train, so I will post photos later.
