Posted: Thu Nov 10, 2005 7:38 am
If I had the money, I would buy the Southerly 110 from Northshore Yachts in England. Price tag $213,000 at the current exchange rate. Practical Sailor said Beachable yet able to navigate open-ocean waters. The swing keel is operated by a hydraulic ram with electric pump. The system has a manual back-up which takes only 3 minutes to raise the keel. She can be sailed with the keel up but you will make leeway.
Southerly 110 web site
Headroom: 6-4
LOA: 35-6
LWL: 30-3
Beam: 11-10
Draft: Keel up 2-4
Keel down 7-2
Displacement: (lbs) 15,388
Ballast: Grounding plate 4455 lbs. Cast iron
Swing keel, 2310 lbs. Cast iron
Total ballast 6,765 lbs.
(Grounding plate is 4 x 8 x 3 thick and it protects the bottom for grounding.)
Ballast/displacement ratio: 45%.
Righting moment: Keel down 150
Twin rudders
Sail area: 606 SF
Engine: 29 hp
Water: 54 gals.
Fuel: 48 gals.
Headroom: 6-4
LOA: 35-6
LWL: 30-3
Beam: 11-10
Draft: Keel up 2-4
Keel down 7-2
Twin rudders
Sail area: 606 SF
Engine: 29 hp
Water: 54 gals.
Fuel: 48 gals.
