Posted: Thu May 04, 2006 6:20 am
I'm not usually an alarmist on these sorts of matters, but on a tire which is nearly always loaded very close to its capacity (if not over it) I'd say as soon as the cracks appear.How do people make the call as to when to replace...ie...when do you consider the cracking 'serious' ??
Cracks can allow water to penetrate to the belts, beads, etcetera. Don't know how much steel is inside the stock bias tires, but to boaters it's not any secret what water (particularly salt water) can do to steel in a very short time.
As many have reported, tire failure on a trailer tire at 50 psi can be pretty spectacular. And of course, you know it's not going to fail while sitting in your driveway.
At well under $200 for two, including installation, should be a simple decision. If you refuse to consider an additional axle
The stock fender clearance is pretty minimal even when everything is as it should be. And of course it doesn't help that most of us habitually overload the trailer. Before I added the axle to mine, there was evidence the tires were contacting the fenders. Of course any looseness in the mounts to the trailer rails will cause sag as well.i've got "sag" issues with my springs that i need to take care of first.
that is, when the trailer is without Mac, it sits up great.
with Mac, the tires almost touch the fenders.
Unless it's really bad or there's evidence the fenders are actually being driven up into the sides of the boat, I don't think occasional contact will hurt too much.
The fenders and mounts are pretty sturdy, but if you've ever stood on them to reach something in the boat, you may have bent them down slightly. BTDT. Before you consider something more drastic you might try bending them up a little.
