A lot of thought has to go into the disconnect of this unit. The end of the drive bar has a simple shallow hole that drops over the supplied pin with knob. It just lifts off and on. I asked WHITWORTHS as to whether it had ever ' jumped off' the knob, and they assured me, no.
When it was on the VIVACITY it never did jump off.
The only trouble i had with this model was when it started to make a regular knocking sound. Turns out that a piece of HARD grease had got stuck near a drive sprocket. No more knocking after removal .
To work safely, you have to able to ' get to' the top controls. This makes the suggestions of mounting under the transom or inside the hull impracticle. Even though, controls can be left and the simple disconnect of the knob/hole arrangement frees the steering. The unit keeps on pumping even if disconnected.
Even if the steering rods are uncovered, it could be difficult to access from the console seat...getting up, lifting the seat, leaning down,
But I'm working on it...Puggsy 06
